Toplink Buy hyd toplink with or w/o check valve??
   / Buy hyd toplink with or w/o check valve?? #11
Second question--Do you suppose I could use a cat II HD toplink with a 1000 lb chisel plow in tough conditions and have it work or are thse things best with lighter duty conditions?
Toplink selection varies with the implement and the job. When I disc, I don't use a toplink at all. When I use the cone spreader, I have to go to a real short Cat1 toplink. When I use the mowers/rake/boxblade, I use the HTL. When I use the boom pole in high lateral stress situations, I use a HD Cat2 conventional. And the list goes on.
Long story short: if I ever add a 1000# chisel plow to my inventory, I believe I'd go with the HD Cat2 conventional.
//greg//
2003 Walk-Behind Automatic Seed Spreader (A51691)
2003 Walk-Behind...
2018 Ford Explorer SUV (A56859)
2018 Ford Explorer...
2012 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A56138)
2012 INTERNATIONAL...
2014 MACK GU713 WATER TRUCK (A51247)
2014 MACK GU713...
2015 International TranStar 8600 T/A Day Cab Truck Tractor (A55852)
2015 International...
