Rotary Cutter Bush Hog & Woods Dual Spindle Cutters
   / Bush Hog & Woods Dual Spindle Cutters #11
Mike
Could a double action sickle bar mower work?
Just a thought.
Re: SQ84T
OK, I don't think we wanna spend 2 grand on this ine... Now if I get one for $500....
Sickle mower? I dunno... We have some rocks (soft sandstone) and light brush. Are they up to that? Do they require much maintainance? I know nothing about sickle mowers...
Re: SQ84T
Well, I am going to try and decide between the Deere LX6 and MX5. For Now... (No promises, I couls end back looking at others....)
Since that is all Green, and I want some input from owners of mid chassis Deere's, I'll start a thead in JD O/O
Thanks!
   / Bush Hog & Woods Dual Spindle Cutters #14
Re: SQ84T
I've seen some bent up to but I also know how it happened and who was driving and that told the story. The size of the tractor on the front of it does make a difference also. You don't feel to much with a 80 horsepower tractor on them either.
   / Bush Hog & Woods Dual Spindle Cutters #15
A 4310 E-Hydro will not handle a 80 inch machine...72 is max for light to medium conditions.
edv
   / Bush Hog & Woods Dual Spindle Cutters #16
EDV
If you don't mind where in SC are you?
Paul
   / Bush Hog & Woods Dual Spindle Cutters #17
depending on your width of tires stick with a 5 to 6'. I would like to see a loader for ballast.
<font color="green"> A 4310 E-Hydro will not handle a 80 inch machine...72 is max for light to medium conditions. edv</font>
Well, I decided against the Woods (No Way It'd work)
I am almost certainly not going with the Bus Hog. Even though it is 720lbs and rated for 25 Hp, I am not convinced that I wouldn't have trouble with it due to the frame on an offset model. I am really not ready to gamble $2000 that way. I can't seem to find any, and would have to special order it.
Hey edv, can you answer this:
The description I have read for the MX5 suggest that it cuts faster due to its design. Will I cut faster with the MX5 or the LX6? They are roughly the same price, locally.
   / Bush Hog & Woods Dual Spindle Cutters #19
Just to add some fuel to the fire...
I have very good success running a Woods RM600 (72 inch, 3 spindle) mower behind a Kubota B2400 (18 hp at the PTO). This arrangement will perform well when cutting 12 inches of VERY thick pasture grass (in one pass). It also does real well in 4 feet of thistles, bachelor's buttons and other tall weeds.
The blades are kept at factory specifications (razor sharp). I set the engine to PTO speed, place the transmission in low range, and hold the hydro-pedal at full speed. The front loader is not needed for weight on the front either.
UNUSED Safety Work Gloves (A53117)
UNUSED Safety Work...
2006 Utility 3000R 53ft T/A Reefer Trailer (A51694)
2006 Utility 3000R...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2019 Ford F-150...
UNUSED FUTURE FT-CL100C HYD CLAMP GRABBER (A52706)
UNUSED FUTURE...
CATBKTSSL_78 (A55787)
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
