Bush Hog Vent plug??
   / Bush Hog Vent plug?? #1
fishrman
After putting new pads on my slip clutch after I burnt them out I noticed oil leaking out the side plug. I thought that was weird. It was sitting in the sun and not running at all. I opened up the side plug and oil began spilling out. Probably around a 1/4 to a half pint of oil came out of the plug hole. Only thing I can figure out is it was overfilled at some point. To be honest, I don't think I have ever put any oil in it since I bought it and that was probably 4 or more years ago. Anyway, number 1, I am wondering if the vent plug is working correctly. I removed it and when I push on the underside of it, it moves up and back down. Perhaps it is dirty on the inside and not letting air escape?? Not sure what is going on. The side vent plug was very tight so I am sure there had to be a great amount of pressure built up for it to be leaking out there. Just don't know if I need to replace the vent plug or not. Guess it wouldn't hurt. Also, shouldn't the oil level be even with the lower part of the hole on the side plug? Do you guys ever try to replace the oil or do you just make sure there is enough in the gear case? Thanks for your help! This is on a SQ160.
   / Bush Hog Vent plug?? #2
The plug on the side is not and should not be a vented plug. The side plug is the proper oil level for the gearbox. The vented plug should be installed in the highest location which is where you'd fill the gearbox.
I haven't replaced the oil on my king kutter since it was new 30 years ago. It was filled with synthetic gear oil from the manufacturer and there were special instructions that said NOT to install a vented plug. There are some special gear oils that don't require venting of the gearbox...we've used them in some critical pharmaceutical applications.
Yes, I knew the vent plug goes on the top and that is how it is. So the bottom of the hole on the side plug would be the proper level for the oil? Is there a way to know whether or not the vent plug is working correctly? Seems to me it should have vented out that plug and not out the seams of the side plug. Maybe I should replace the oil with the special oils that don't require venting?
   / Bush Hog Vent plug?? #4
correct, side plug is proper oil level, usually the vent plug on top also serves as fill plug
i've seen 2 types of vent plugs, newer models usually have a spring loaded check valve. older machines sometimes have a bundle of fine wires to vent.
i'd recommend installing a new vent plug for your model. shouldn't be hard to track down. a small expense, compared, say, to ruptured input/output shaft seals
also through the years moisture may have accumulated in the gearbox raising the level hence your issue.
get the new plug, ensure it's working, then change the entire gearbox oil. search the manufacturers recommendation for grade
i personally use 85/140 gear oil (conventional) but check your particular model recommendation best regards
Thanks! The one I have is spring loaded and the spring seems to be working but if it were truly working, I wouldn't think the oil would be pressured through the plug on the side. Anyway, I think you are giving good advice and believe that is what I will do. I will see if I can track down a new check valve Monday, might have to order but will check at local dealer. I will suck the old oil out and replace. Book calls for 80/90 so guess I will go with that. Not sure how much I will need?? I would guess, at least a quart??
   / Bush Hog Vent plug?? #6
This should help:
6. Gearbox - Check oil level by removing oil level
check plug on right side of gearbox. Add EP80W-90
gear oil if necessary to bring oil level to check plug
hole. Capacity of SQ142 and SQ148 is 1.6 quarts
(1.5L), SQ160 and SQ172 is 2 quarts (1.9L). Capacity
of SQ184 is 1 quart (.95L). Capacity of SQ-84T
Iv.maintenance; Maintenance Check List; Lubrication - Bush Hog SQ142 Operator's Manual [Page 12]
Thanks, didn't see that in my book! Looks like I need 2 quarts of 80w-90. Interesting the SQ184 takes less than the 160. Thanks again, big help!
   / Bush Hog Vent plug?? #8
Welcome glad to help.
especially since I'm a novice, unlike the many seasoned hands here ..lol...blind hog and all that....have a great weekend.
   / Bush Hog Vent plug?? #9
I think that it is strange that it would leak out pipe threads before it leaked through the shaft seals. You may want to check for a crack in the case at the side plug. The housing can crack if the tapered plug is over torqued.
Oh great! Now you have me worried about that! I suppose that is a possibility though, I will check closer tomorrow! The reason I am now worried about that possibility is that it wasn't leaking before I took it to the dealer to have him put new pads on and he told me that he greased it all up and checked the fluids and took some fluid out because there was to much in it. Now, I am wondering if when he put the plug back in he may have overtightened it! If he did, I am not going to be a happy camper. On the other hand, unless there is an obvious crack there, it is going to be hard for me to see. Someone suggested I put plumbers tape on the plug. If I do that and it still leaks, I guess that would tell me there is probably a crack there?? Oh, I hope you are wrong but it is to late for me to check it out now till tomorrow!
2014 Doosan DA30 (A51039)
2014 Doosan DA30...
(2) Heavy Duty Tow Straps (A50860)
(2) Heavy Duty Tow...
2018 Terex RL4 4000W Towable Light Tower (A49461)
2018 Terex RL4...
2012 Mclaughlin V500LEHD Vac Trailer (A49461)
2012 Mclaughlin...
2017 Miller Nitro 6300 Self Propelled Sprayer (A50657)
2017 Miller Nitro...
2015 Revere Shasta 27DB 5th Wheel Travel Trailer (A48082)
2015 Revere Shasta...
