Bush Hog spline to hub play
   / Bush Hog spline to hub play #1
Avondale
Platinum Member
Apple Hill, Ont
Kioti DK35 and Kioti NX6010
Good Morning,
I have a 10 year old Bush Hog SQ600 rotary cutter that has some slop/play at the hub, where it interfaces with the gear box splined output shaft. Is this a normal, fair wear and tear type event for this age and does anyone know how much is too much before replacing the hub? The mating ridges/grooves of the hub are somewhat rounded off while the shaft spline ridges are still fairly squared off. I've been told that the hub material is engineered to be softer than the splined shaft to reduce the likely-hood of damage that would involve a gearbox repair effort.
Thanks in advance for whatever help you can provide.
Bob
   / Bush Hog spline to hub play #2
If your talking about the hub in the blade bar - stump-jumper, then there should be no play. Should be a tight fit.
   / Bush Hog spline to hub play #3
On some (most?) of their stuff, Bushhog uses a weird tapered bolt to lock the drive hub (at least of slip clutches) onto the input shaft of the gearbox. My 286 hub was a little wobbly too. I punched the tapered bolt out and de-rusted it good with a wire wheel. I believe that at least part of its clamping force is intended to be from it ROTATING snugly into the groove around the gearbox input shaft as it is tightened. So if it's rusty, it won't rotate as designed. I put a film of lube on it when I reassembled and it does seem to be less wobbly now, but there is still some play.
   / Bush Hog spline to hub play #4
I'd say if turns don't bother you keep at it but somewhere down the line time to upgrade. Obviously any wobble will just accelerate the destruction of the yoke.
   / Bush Hog spline to hub play #5
Post some pictures (or a video) showing exactly what you're seeing.
2018 Chevrolet Bolt EV Hatchback (A48082)
2018 Chevrolet...
19008 (A48082)
19008 (A48082)
JLG 1255 Telehandler (A51039)
JLG 1255...
John Deere Planter (A50860)
John Deere Planter...
2011 Ford F-250 4x4 Pickup Truck (A50323)
2011 Ford F-250...
2008 JACK COUNTY  130BBL VACUUM TRAILER (A50854)
2008 JACK COUNTY...
