Bush Hog shear pins
   / Bush Hog shear pins #1
shu
tip of texas
Case IH 45A
Was reading posts about shredder shear pins.
Have Bush Hog RZ60 on a New Holland TC30.
One lot I mow is not unusual to go through 3 or 4 a day.
We have 5 acres last used as an ag chemical dealer yard. The ground is overall level, but with plenty of dips and humps. Cover is guinea grass, grows about 4 ft tall from clump bases. When the place was closed out 10 years ago the folks left small piles of junk around the back 3 acres. Since then the neighbors have added more stuff.
I learned about shear bolts when I first cranked the bush hog after the dealer installed it. I popped the clutch at the operating 5400rpm, and WHAM! Took me two days and a 40 mile trip to find a place that carries grade 2 bolts. I bought 3. No, I did not consider for more than 2 seconds using a standard grade 5 bolt.
I keep the FEL down to feel for trash when I mow this place. With the uneven ground and the clump bases of the grass there is much that slips by to the mower - pieces of 4x4, logs, old oil filters, trailer tires, balls of wire, chunks of concrete, old toaster oven, etc.
I carry a bag of shear bolts and tools in a 5 gal bucket on the shredder deck. I keep the shear bolt area (and other points) well greased.
After two passes, I about have most of the junk worked out of there. The other places I mow, level ground in bermuda grass and low weeds, are no problem.
The rear PTO of the TC30 is stiff to engage. Best way I found is let out the clutch (at idle power) till the gears start to engage. Then the lever moves easily.
BTW, that old ag chemical yard also had a berm 2-3 ft high and 120 ft long between the front and back sections, apparently buldozed up before the yard was closed to keep folks from driving across it. Chunks of railroad tie, tires, and other junk mixed in with the dirt and all overgrown with well established grass.
Taking down that berm was my first job when I got the TC30. There were some concrete pylons 15 inches square and 18 feet long built in there. Took all the power that little tractor has, but but it pulled them out after I had got them mostly dug free with the FEL.
   / Bush Hog shear pins #2
<font color="blue">(…is not unusual to go through 3 or 4 a day…. I carry a bag of shear bolts…)</font>
/forums/images/graemlins/laugh.gif WOW… you’re a glutton for punishment…! /forums/images/graemlins/smile.gif
I wouldn’t be wasting all that time on replacing shear bolts… when it’s a whole lot easier to install a slip clutch and be done with that problem once and for all… /forums/images/graemlins/blush.gif
   / Bush Hog shear pins #3
I mow about 5 acres as well, tell me about this slip clutch. Does it install on the bushhog. Thanks.
Slip clutch. May look into that.
Usually I keep my stuff pretty much stock till i get comfy with it.
Thanks.
   / Bush Hog shear pins #5
Shu, what do you use for shear pins on your RZ 60? Grade 2 bolt? Grade 5 bolt? What size? Nuts?
Other posts on the site seem to indicate that factory replacements are comparitively expensive vice going down to Tractor Supply for bolts.
Bush Hog RZ60 Op. Manual specifies 1/2 x 3 inch grade 2
shear bolt and locknut. That's what I use, except regular
nut and lock washer instead of locknut. Don't have a receipt
at hand, but the bolts are about what you would expect to
pay; 0.35 each or so. The hard part is finding a store
The bolts I found are threaded for most of the length,
whereas the original bolt was just threaded about the last
inch. The longer threading decreases the cross sectional
area, making the bolts fail more easily than the original.
From reading other shear bolt posts it appears Bush Hog
may use special shape pins in some mowers; probably to
keep folks from using ordinary grade 5 bolts.
CATERPILLAR 108" WHEEL LOADER RAKE (A52707)
CATERPILLAR 108"...
2012 FORD F-550 SUPER DUTY CAB AND CHASSIS (A58214)
2012 FORD F-550...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58214)
2011 MULTIQUIP...
LOT: Welding Accessories: (2) Auto Darkening Helmets, Welding Rods, Welding Wire, Magnetic Arrows (A59076)
LOT: Welding...
(8) 2" x 27' , 5 Ton Ratchet Tie Downs (New/Unused) (A59225)
(8) 2" x 27' , 5...
2018 DODGE RAM 2500 (A58214)
2018 DODGE RAM...
