Rotary Cutter Bush Hog Flail Mower FM60 - Bearings
   / Bush Hog Flail Mower FM60 - Bearings #1
jc7622
Edmond, Oklahoma
Montana 5740C
I bought a used Bush Hog FM60 flail mower and one of the bearings on the roller went out today. From the link below I am needing part #'s 12, 13 and 14. Does anyone have any idea where I could find some kind of a cross reference so that I can buy the parts locally?
BushHog Parts Diagrams
Also, I am having a heck of a time getting the inner part of the bearing off the roller shaft. Any tricks on how to get it off?
   / Bush Hog Flail Mower FM60 - Bearings #2
go to flailmaster.com
Thanks for the tip. Unfortunately they only sell blades for most brands.
I'll go ahead and update this in case anyone comes across it while searching for info in the future.
I talked to Bush Hog and the only part numbers thay have are their own. They don't have any Timken bearing numbers that can be cross referenced.
I also have a King Kutter rotary cutter and they gave me part numbers for bearings that I could get at Napa or wherever.
   / Bush Hog Flail Mower FM60 - Bearings #5
Take bearings to a bearing and belt supply, they can measure what you have and will have, or can get you what you need. I have done this on a flail mower, the company no longer in business. I have done this with seals as well, never a problem.
2018 Ford Fusion Sedan (A55853)
2018 Ford Fusion...
2024 John Deere 8R 410 MFWD Tractor (A53485)
2024 John Deere 8R...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
1980 ATHEY AB6905 MOTOR GRADER (A52707)
1980 ATHEY AB6905...
2015 Chevrolet 1500 Silverado Pickup Truck (A55852)
2015 Chevrolet...
