Bush hog blade stopping
   / Bush hog blade stopping #72
I'm in agreement with others who suggest this being a hydraulic issue. I'd take a close look at the various filters for the hydraulic system. The HST might be taking up as much of the hydraulic flow as possible and leaving insufficient flow to drive the PTO. With low-load there's enough flow for the PTO to handle the lighter grass.
Not sure how possible it is, but perhaps try putting your tractor into your higher grass and run the RC while NOT in gear/traveling. This would assure that all available hydraulic flow is available for the PTO. I'm no expert in any way on hydraulics, but I'm thinking that IF the cutter is able to cut w/o any issues that it wouldn't be a PTO clutch-pack but a basic system flow issue (filter would be an issue perhaps- I know that there are things like strainers- my B7800 has one and it's maintenance schedule calls it out to be cleaned).
Please note that "filters and fluid changed [recently]" isn't qualifying things. No idea if the prescribed procedures were done PROPERLY. Again, note my comment above on the strainer. If someone doesn't know about something like this then it's something that is likely going to be missed (until one finds one has a problem).
   / Bush hog blade stopping #73
The HST is a separate hydraulic pump and motor combo. The only thing it shares with the rest of the hydraulics on the tractor is the fluid.
There is, however, two hydraulic gear pumps. One, the smaller one, handles the steering and the PTO clutch pack (lube and pressure). The second and bigger pump runs everything else on the tractor like, loader, 3pt and remotes.
To the OP, at this point, just grab the workshop manual for that tractor, get a pressure gauge and figure where to check the clutch pack pressures using the manual as guide. Then proceed from that.
Did not check the pressure. Have no gauges at this time to do so. Will check the NH manual to see if there is a screen. Since my main tractor is down and I need to get areas mowed before grass waterway work can be started I mowed at follows. Tractor RPMs as should be, very slow forward speed. Mowed first 18 inches high, then 12 and then 6 or so. Got the mowing about done but it was very slow. Took about 4 times longer than normal but as least I was able to get it done almost. Did not bog down much so overall it worked.
I do not want to bring it to the shop at this time or I am without a mower.
   / Bush hog blade stopping #75
This was OP’s post (#14).
Seven pages later and we’re still wondering where the problem is?
If the tractor’s PTO shaft nearly stops but the tractor engine’s rpms do not drop, it’s an tractor PTO problem.
No, we're not all wondering. Not but one thing it can be.
   / Bush hog blade stopping #76
Check the pressure asap, if the clutch pack isn't fried yet it will be in short order if you keep using it. Not familiar with the NH but other brands use a relatively low pressure for the clutch pack, usually around 4-500psi. Gauges and adaptors are cheap, the clutch pack and time to replace are not!
Hopefully its just low pressure and you can catch it in time and save it.
I have parked it for now.
   / Bush hog blade stopping #78
Right answer.
Just an update. I am thinking it is a PTO issue. When the PTO was turned off the noise ended. Also with the PTO off the tractor functions and operates normally with full power.
If it is a PTO seal etc. issue is that an expensive fix? For what I need to do now, loader work etc. I do not need the PTO.
Can use my other tractors for that but just curious if any idea about such repair costs for anyone having had that done. Thanks
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A57024)
NEW 2025 Load...
(INOP) CATERPILLAR 914G WHEEL LOADER (A52705)
(INOP) CATERPILLAR...
2012 Dodge Charger Sedan (A55853)
2012 Dodge Charger...
2008 Ford Fusion SE Sedan (A55853)
2008 Ford Fusion...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
1996 Parker Trailers TravAlong T/A Gooseneck Livestock Trailer (A55787)
1996 Parker...
