Bush Hog blade replacement
   / Bush Hog blade replacement #1
yanmars
Veteran Member
I had a bolt come out of my bush hog and one blade came off. The threads are pretty mangled. I have a replacement. Any trick to replacing it by myself. I think I can get the new in and started, unsure how much torque I will need to tighten it down and how to hold the blade to do that. I only have hand tools. Any ideas are welcome. Any reason to add lock tite?
   / Bush Hog blade replacement #2
...Any reason to add lock tite?
Yea, So it doesn't happen again... :D :D
I had trouble getting the thread started... bolt falling out. I did it myself and it wasn't fun. Do you have another set of hands?
I think I ended up duck taping the bolt in place to get the nut on.
Thanks for the information. I will see what I can do, if not I can take it off and bring it to my tractor shop.
   / Bush Hog blade replacement #5
I stick the bolt through and let the weight and leverage of the blade bind the bolt in the hole. Tighten with a breaker bar. Did the new bolt come with a lock washer? I've never had an issue with using a lock washer. Another option would be to drill a hole in the bolt to use a cotter pin the keep the nut from coming off.
It did come with a lock washer. Access is through a hole in the top of the mower deck, might be hard to get a cotter pin in. Also the stump jumper is pretty tight to the deck so not much room underneath to gain access.
Chicago Air Tugger Winch (A50860)
Chicago Air Tugger...
Chevrolet C8500 Flat Bed with a Moffet Kit (A51039)
Chevrolet C8500...
2018 Mack PINNACLE CXU613 Sleeper Truck Tractor (A50860)
2018 Mack PINNACLE...
5th Wheel Dolly (A49461)
5th Wheel Dolly...
2014 Freightliner Ambulance (A50323)
2014 Freightliner...
2020 KUBOTA SSV75 WHEELED SKID STEER (A51242)
2020 KUBOTA SSV75...
