Bush Hog ASV RC60
   / Bush Hog ASV RC60 #1
Blackhammer
Florida
I have a RC 60 and have used a 60" heavy duty mower on it before and it worked great. Now I am looking into bidding on a contract that is monthly mowing of 4 landfills about 425 acres total. If I get the contract I will probably get another larger machine but I want to know what you guys think. The project is priced per acre so time is money. How long do you think it wil take per acre.
   / Bush Hog ASV RC60 #2
depend on what you use to mow it with and how thick/tall the grass is.We use 110 hp cab 4x4 with 15 ft batwing so we should be able to mow it fastes than the rc60
   / Bush Hog ASV RC60 #3
Blackhammer ,
Someone might check my figures, but at 5 mph and cutting 5 ft wide, = 132,000 sq ft per hour
1 acre is 208 x 208 = 43,264 sq ft
425 acres x 43,264= 18,387,200 sq ft. divided by 132,000 = 139 hours.
5 mph = 139. hr
10 mph = 69.5 hr
3.29 acres per hr @ 5 mph
6.11 acres per hr @ 10 mph
If these figures are not correct, please fix.
Did not figure any overlap in cutting, but you probably overlap about 12 in, which will increase the time.
   / Bush Hog ASV RC60 #4
what's the terrain like and how thick is the vegetation.
The fastest I have mowed grass in a RC100 with a bobcat 60" rotary was 7mph, it was thin and dead. For thick stuff, I can only do 3-4 mph with a 72" bradco, I was happy with 2 acres per hour.
My batwing at 3 mph in the same tough stuff was knocking down 5.5 acres per hour.
You'll get killed bidding against tractors with batwings if the terrain allows them. If it's steep or on a hillside, you have a chance.
Good luck.
   / Bush Hog ASV RC60 #5
JJ,
For the record an acre is 43,560 square feet. Everything else looks correct. :D
   / Bush Hog ASV RC60 #7
425 acres is a lot of mowing even with 15' batwing. I would try to find 20' batwing just to make it easier. 15 footers are much more common.
5' mower on skid steer won't have a chance. Based on the 139 hour estimate, it would require mowing 40 hours per week and then start over again. Also the efficiency/power of a hydraulic driven rotary mower is poor compared to pto driven mower.
Your only reasonable chance is buying a used 15-20 batwing and used 80-115 hp tractor. New would be way too expensive unless you can find other jobs. Good used tractor and batwing is probably 50-60% cost of new. Tractor cab highly recommended.
   / Bush Hog ASV RC60
2 of the sites are land fills that are closed. The terrain would be hairy in a tractor. The contract is for 1 cut a month. I am going to find out what the current contract holder is using to mow the land. I figure the grass will probably be fairly thick and about 15" to 24" tall. the wet areas will be worse. I am meeting with the waste management super tomorrow to see if it is doable.
   / Bush Hog ASV RC60 #9
Has the area been flattened and track rolled ? If not it will be a nightmare of whoops and hollows and sharp things sticking out of the ground to tear up tracks and tyres and also have soft spots to get bogged in . Maybe you can ask them if you could use a trailed wick wiper and Roundup to keep the grasses and weeds at bay .
   / Bush Hog ASV RC60 #10
Iron Horse, our closed landfills are required to have a 36 inch dirt cap and be covered with vegitation to prevent erosion. Using Roundup would not be an option since you need the grasses and weeds growing on the area as per local laws.
I personally think that you need at least one of those off road high horsepower tractors towing a mower or you will spend most of the month on one job. 450 acres is a huge area so consider wisely as you bid. Your business is different than mine so maybe you can make it work, I hope so.
JLG 1255 Telehandler (A51039)
JLG 1255...
Informational Lot - Financing (A51039)
Informational Lot...
2007 MD-8 TRIPLEX PUMP POWERED BY 1050HP MTU ENGINE (A50854)
2007 MD-8 TRIPLEX...
MAXUM M-1000 TRIPLEX PUMP POWERED BY 3412 CATERPILLAR ENGINE (A50854)
MAXUM M-1000...
2018 John Deere XUV560E 4x4 Gator Utility Cart (A50322)
2018 John Deere...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A51039)
Kubota 24in Quick...
