Bush Hog as cultivator
   / Bush Hog as cultivator #11
Bob,
Welcome to the Great Lakes State!
I am sure you will enjoy the museum, and I hope you take time to go through Greenfield Village also.
Have fun,
Abe.
   / Bush Hog as cultivator #12
ldabe said:
Bob,
Have fun,
Abe.
I remember when i was a kid going thru the Henry Ford museum and Greenfield Village. I thought it was Great!
   / Bush Hog as cultivator #13
First it sounds dangerous. However the mulching blades I've seen have a stiff spring mounted to the blade such that when in motion it drags the ground. The spring has a tip of straight about a few inches that touches the ground. The coil portion does not. Also the straight tip is what drags the ground and it tilted in the same direction of rotation. This way it gives and just rips the top of the ground.
I will say after using one of these on a lawn mower. They make a lot of dust. I mean a lot.
Mounting bolts that point downward from the blades I think will break a shaft when it hits something solid like a root, rock, etc.
Anyways, Mounting parts to the blade sounds really dangerous as the ends are moving really fast. Making that much contact with the ground you are going to break something and will be dangerous when it goes flying.
I think rippers may be the cheaper alternative.
Kubota M4700 4WD 51HP Utility Loader Tractor (A56857)
Kubota M4700 4WD...
2009 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2009 Ford F-150...
2014 MACK PINNACLE (A55745)
2014 MACK PINNACLE...
2010 Chevrolet Traverse SUV (A56859)
2010 Chevrolet...
12V Diesel Fuel Transfer Pump (New/Unused) (A59225)
12V Diesel Fuel...
1992 Ingersoll Rand 185 185CFM Towable Air Compressor (A55973)
1992 Ingersoll...
