Bump up lift capacity of L3400/LA463 Loader
   / Bump up lift capacity of L3400/LA463 Loader #21
2700-2800 would about be my max. If you want more grunt, get some 2" diameter cylinders.
   / Bump up lift capacity of L3400/LA463 Loader #22
I'd be more curious to learn what it will do to/for the drive systems on the HST's. Running it over rated pressure could cause more problems then its worth.
just my $0.2..
Jim
   / Bump up lift capacity of L3400/LA463 Loader #23
Would this modification also increase the TPH lift capacity?
   / Bump up lift capacity of L3400/LA463 Loader #24
just my $0.2..
Jim
No impact. Separate systems, only thing in common is the fluid. The pump for loader and 3pt is on the side of the engine. The 2 pumps for the HST are in the transmission case.
jb
   / Bump up lift capacity of L3400/LA463 Loader #25
Thanks for the input! Mine will remain at 2750 and works just fine.
   / Bump up lift capacity of L3400/LA463 Loader #26
Yes, the relief valve for the loader is the same one for the 3pt hitch. Don't expect massive gains. Unless your relief was tired and you then go from 3-400 psi under spec to 200 over spec.
It is important that you use a gage to measure the pressure, don't just guess that it was low and add a wad of shims. That wouldn't be smart.
jb
I now have a 5000 psi wet gauge in hand and just need to figure out the fittings to hook it up. I will post when I have more information. Brian
   / Bump up lift capacity of L3400/LA463 Loader #28
Brian,
Sounds like you are well on your way. I am interested in what you find out about the proper fittings needed to put your guage together... I need to do the same. Pictures, part numbers... anything that would help the rest of us put a guage together, would really be appreciated. I look forward to your end results also... I know my L3400 with LA463 loader is a bit weak on the lift capacity, and I'd love to improve it. Thanks for keeping everyone posted.
   / Bump up lift capacity of L3400/LA463 Loader #29
If you can just hook it up to the bucket hydraulics, all you will need is a quick-disconnect fitting like the one below. I think the quick disconnects used on the bucket hydraulics are 3/8" ISO Series B fittings.
Quick-Disconnect Couplings
Part# 95825K82
   / Bump up lift capacity of L3400/LA463 Loader #30
What affect would this have on a bh75 hoe?
Actually just bumping the thread..:D
2010 Chevrolet Tahoe SUV (A56859)
2010 Chevrolet...
2015 Ford Fusion Hybrid Sedan (A56859)
2015 Ford Fusion...
Swict 72" Bucket (A57149)
Swict 72" Bucket...
2008 TEREX TRAILER LIGHT TOWER (A58216)
2008 TEREX TRAILER...
2006 IC Corporation PB305 Bus (A56858)
2006 IC...
(INOPERABLE) DYNAPAC DOUBLE DRUM ROLLER (A58216)
(INOPERABLE)...
