Bullet in Trim
   / Bullet in Trim #1
downsizingnow48
Elite Member
Sacramento, California
Kubota B21
There is a first time for everything. I am using California white cedar from a local sawmill for jamb extensions on the new windows. The white cedar is much nicer to work with than what is available at the big box stores. Cutting a batch I noticed something shiny. I had just cut through the middle of a bullet embedded in the wood.
   / Bullet in Trim #2
Make up a "legendary" story about the wood coming from a famous saloon and keep it. $$$$
   / Bullet in Trim #4
Same thing happened to me a few years back...and here again, the wood came from a local sawmill.
   / Bullet in Trim #5
Timber companies here lease hunting rights to their planted pine forests.
Every property I have been a part of have a shooting lane between rows of pines for checking rifles and some fun.
Every tree for 300 yds down those lanes has been hit with a bullet.
I'm sure the mills love it when those rows are harvested!
   / Bullet in Trim #6
I thought of instead of building a US/Mexican wall, why can't we just have a shooting range alone there?
   / Bullet in Trim #8
Yep, having working in the pulp and paper industry for years, you would be amazed at the number of bullets that were found in the bottom of the pulp receiver tank just after the pulp came out of the digesters. The hardwood forests here in PA are full of trees with bullets in them from all the deer hunters.
   / Bullet in Trim #9
It's sometimes interesting what you find when opening up a tree. Other times it's expensive, as any sawmill owner will tell you.
My father had a bolter mill that he used to cut up pine which we would then use to make boxes to plant seedlings in. (Powered by a hit and miss one lunger engine. :thumbsup:) I don't remember everything he found, but do recall that he split a bullet in half.
   / Bullet in Trim #10
Interesting. Many years ago I fell an ancient pine out at the end of the garden. The homesteader must have used that tree to hang a gate on - long ago.
Lo & behold - I found a large piece of angle iron deeply embedded - with my chain saw.
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A55315)
Michelin CARGOXBIB...
2006 Heil Tanker Trailer Heavy Duty 65K GVWR Tank Trailer (A56435)
2006 Heil Tanker...
2016 Chevrolet Cruze Limited Sedan (A56859)
2016 Chevrolet...
2013 Ford F-150 4x4 Pickup Truck (A55852)
2013 Ford F-150...
30KW GENERATOR (A58214)
30KW GENERATOR...
