Building my own Leaf/Grass Vacuum system
   / Building my own Leaf/Grass Vacuum system #11
Here is some links to the leaf collector that I have that doesn't have the self unloading catcher for it. I will try and grab some pictures of that other one in the next couple of days in case anyone is interested in how it works or just in it period.
David from jax
http://img.photobucket.com/albums/v177/sandman2234/tractors/MVC-002F.jpg
http://img.photobucket.com/albums/v177/sandman2234/tractors/MVC-003F.jpg
This one was taken while running, which explains the blurr.
http://img.photobucket.com/albums/v177/sandman2234/tractors/MVC-004F.jpg
http://img.photobucket.com/albums/v177/sandman2234/tractors/MVC-005F.jpg
http://img.photobucket.com/albums/v177/sandman2234/tractors/MVC-006F.jpg
http://img.photobucket.com/albums/v177/sandman2234/tractors/MVC-007F.jpg
This is what happens you start dropping things into it that you shouldn't. It would have never picked up the piece of wood I dropped into it, just to see what it would do.
http://img.photobucket.com/albums/v177/sandman2234/tractors/MVC-008F.jpg
http://img.photobucket.com/albums/v177/sandman2234/tractors/MVC-010F.jpg
http://img.photobucket.com/albums/v177/sandman2234/tractors/MVC-012F.jpg
Hopefully this won't hi-jack this tread, or do you think I should start another one?
David
Don't worry about hi-jacking the thread, anything about blowers/vacs is good stuff.
I just got back from a weekend trip. On Friday, right before i left my 8" hose had arrived, so I can now get back to the project, hooking up the parts that are ready.
Last will be making to topper for the collection trailer, won't be a problem, just some more work.
   / Building my own Leaf/Grass Vacuum system #13
A good piece of heavy duty cloth that is loose woven to allow air to flow thru it but stop the dust would make a good top. The leaves that are picked up usually drop to the bottom, especially if your chute is turned down, but the dust just goes everywhere. Stopping most of it would be a very good idea, but you can't stop the air flow or you will cavitate the blower.
David from jax
   / Building my own Leaf/Grass Vacuum system #14
However, after the accident and my termination, I may be putting both of them on ebay along with the extra impellers.
David from jax
David, this doesn't sound good. Is the rest of the story in another thread somewhere?
   / Building my own Leaf/Grass Vacuum system #15
Due to some legal ramifications, I requested that complete post be removed.
Keep my family in your prayers.
SkunkwerX,
Have you considered what you are using for a top and how the whole unit will control dust?
I recently purchased a parts machine Jacobson diesel mower and the air filter on it is looking pretty good to double filter the engine on my lawn mower, which is what I use to pull the Giant Vac with.
David from jax
   / Building my own Leaf/Grass Vacuum system #16
I inherited a system almost exactly like you are building. It works well and it is very handy if I get rained out on the weekend and the grass gets too tall.
It can also be used as a leaf blower to make piles for the kids, by just grabbing the outlet hose you have a riding leaf blower. The biggest problem is dumping the grass and leaves. My cart is a dump type and the back has a swing door. You have to phisically drag the grass clippings out of it, I have even backed it up to a ravine and put the cart verticle and the stuff still will not fall out. Even relativley dry grass is damp when you cut it and pack it in the cart with the blower
   / Building my own Leaf/Grass Vacuum system #17
Bernie,
Have you considered any ideas that would allow the leaves or grass to come out easier? Simple things like spraying "Pam" or silicone on it might work, or purchasing a piece of flat plastic such as Delron. Some of those plastic's are very slick, and very abrasive resistant. A lot of it is used as bearings in places where metal bearings won't work, like around acid tanks, etc.
I don't have a clue about the prices of the stuff, but maybe something will be cheap enough.
Strange that I mention "Pam and Silicone and cheap" in the same paragraph. Wonder what Pamela Anderson is doing these days? (actually really don't care)
David from jax
Hey guys,
I had a chance to use an actual Trac vac for several uses.
The way they deal with the output into the trailer/hopper is to place a vent on top, above where the outlet goes into the side of the hopper.
My best explanation of what happens is akin to a dust collection system in a woodshop.....the blowing air escapes out the vent, the "heavier than air" particles lose their "lift" as the air escapes and they don't make it out of the vent. When i looked back I could tell when i was nearly full, as i would see smaller particles comig out of the vent. it's like a reverse hood scoop on a muscle-car.
That is what I am gonig to start with, and maybe a strip of window screen at the back end. I may place a lip, or something on the outlet flange, which would serve to disrupt the the debris as it's going into the hopper/trailer and let the lack of flow, that is being created by the scoop/vent do the rest.
It was really amazing that you didn't need filter material to accomplish the task on the Trac Vac. I'll toss around vent ideas, versus window screen, or filter cloth, etc.
I think it will be a balancing act to find the right amount of Vent area that allows the solids to "fall out" as the air escapes. If 2% of the material escapes, so be it, it's the other 98% I'll deal with.
Dumping: At first i may just be using a removeable rear panel, later on, if I decide to get fancy, I may use some storm door closers, or SUV hatch pistons to allow the door to raise at the bottom, hinged at the top.
Depends on the moisture and the material how well it slides out.
I don't mind assisting it out with a pitchfork, only takes a few minutes and beats raking the lawn! :D
   / Building my own Leaf/Grass Vacuum system #19
Just thinking that a piece of PVC pipe the same size as your hose, mounted across the top of the trailer top (inside) with a bunch of half inch holes drilled in it and a two inch gap cut out of the bottom of it. The 1/2" holes would disapate the air and the two inch wide gap all the way across the bottom would allow for leaves to fall out. Starting with a two inch wide gap, and going up from there to allow for the leaf size and how much mulch you put thru it. (Easier to cut more than to try and replace a piece, although a sheet metal cover would be easy to make.) A two inch gap would probably handle most of the mulch that makes it thru my blower.
By the way, what is the thickness of the blower casing you purchased. I know mine is a commercial unit, but yours appears to be a little on the thin side, but pictures are often misleading.
Just a thought,
David from jax
   / Building my own Leaf/Grass Vacuum system #20
Don't over think the outlet on the trailer. Mine works just fine with a flat deflector welded to the end of it at about a 45 degree angle. Originally the designer (my wifes father) had about a 2 foot square vent in the top. It was made from some metal that is kinda hard to describe. It's a piece of sheet metal, about 16 gauge that is not quite screen in that it is a solid sheet but it has little holes so close together that you can see through it. I thought this wasn't enough and it would sometimes plug up with debris. I found enough of the same metal to cut the whole top out and make the whole top the vent, performance was improved.
As far as mods to make it unload faster here are a couple of options I have thought of. A piece of chain link fence cut so that will wrap from the bottom rear up over the vent in the front and to some point on the top so I could tie it to a tree and pull it out the back. Another option I have entertained is to do away with the back door and make the sides top and back one piece and make them pivot up on some hatch-back struts to make it easier to dump without the sides to cause drag. .
Sandman, you have given me another idea. I deliver to a place that sells uhmw(sp) sheet, that might be the ticket to get the "brick" to slide out.
I will have to see if they will cut me a deal.
CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A50458)
CATERPILLAR D8T...
Vacuworx MC3B Vacuum Lifter (A50860)
Vacuworx MC3B...
2000 PETERBILT 379 FLATBED TRUCK (INOPERABLE) (A50854)
2000 PETERBILT 379...
Tarter 2 Horse troughs (A50860)
Tarter 2 Horse...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2012 CATERPILLAR 259B3 SKID STEER (A51242)
2012 CATERPILLAR...
