I have a cutoff type saw that just isnt cutting it any more. it cant cut a 4x4 it just doesnt have the reach I need plus a raidial would be sooo handy to take care of riping etc.
I am thinking of using 2 pieces of angle iron for the rails. I was looking through to figure out what to use for bearings so that the saw can glide back and forth. after thinking and looking for a while i came up with roller skate/blade wheel bearings and or wheels. 4 on top at the corners of the plate holding the saw. 2 on bottom and 2 in the middle pushing aginst the sides of the angle iron to keep it centered maybe even 4 aginst the sides depending on how small and if they can fit well together.
the sliding part would be Ibeam shaped to fit inbetween the 2 angle pieces with a small pipe welded to it. in the pipe would be a 2nd smaller pipe that would have 6-8 more bearings attached to the smaller pipe so that they would take the pressure though a lazy susen type might work well between the pipe and the i beam. same setup again to attach the angles to the upright on the table. will probably draw up an idea soon and attach it.
