Bucket attached pallet forks
   / Bucket attached pallet forks #11
I've two pair of the Titan pallet forks, one pair for each tractor, or put all four on one :) each pair with a stabilizer bar.
Often when I just need to move one log or object I'll just clamp on a pair and forget the stabilizer bar. But if I'm doing a bunch of pallet or log movement the stabilizer bar comes in REAL handy.
When I'm moving brush
it is handy to have a chain, ratchet strap, or rope to throw over the pile so it acts as a clamp. I call it my "poor man's manual grapple".
I'd like to get a grapple but other attachments have taken priority and I don't have QA yet.
   / Bucket attached pallet forks #12
Except for the Drive-In Forks that are linked and discussed, you will find the bucket forks will take more time to attach than swapping your SSQA bucket for your forks and back again. Personally, I have my forks on way more than my bucket but that is because lifting and carrying is a more common task for me than having a need for the bucket - if I ran a dairy farm, this would not be the case.
I had a set of bucket forks for my B21 without an SSQA and loved having them (got three so I could use them for brush hauling) but the B21 has a very stout bucket unlikely to easily be bent and I really did not have another option. Putting the load out front certainly limits your lifting though and again, putting them on and taking them off took me more time than driving over to my SSQA forks and swapping implements - I have a 4n1 so I also have hydraulics to swap and it still only takes me 5 minutes (if I take my time).
flingwing1969;5016457 Putting the load out front certainly limits your lifting though and again said:
Likely true and just swapping out may be the best course as I think about all this. There are some other good options suggested here, but I also keep my tooth bar on the bucket most of the time and thus some of those options would not work with the tooth bar on. On the Titan Pallet fork link that Newbury provided I saw some debris forks that really looked interesting and with a significant lifting capacity would be very versatile but again the tooth bar would have to be removed. Thanks for input.
   / Bucket attached pallet forks #14
Debris forks are great to have. As I mentioned, I keep my forks on 80% or so of the time and I live in woodlands so lots of debris to pick up and dump. They are covered in snow right now, but I made a real simple set of debris forks that attach to my forks (I have to take a picture of that thing).
Anyway, here's what I did:
1. I welded on a receiver hitch to the bottom crossbar on the forks that I use for attaching homemade implements and for pushing trailers around the place. Like this:
2. I got a big length of rectangular tubing the size to slip over the forks and some 2x2x1/4 tubing for the forks and a big chunk of 4x4x1/4 angle iron and a piece of receiver 2" receiver tube I had laying around.
3. I cut two 6" chunks of the rectangular tubing put the forks as far as they would go on the carriage and slipped the chunks over them, sliding them all the way back.
4. I cut the angle iron to the length of the width across the forks and tubing, at full width, and welded it to the two chunks of tubing
5. I slipped the receiver tubing into the receiver, slipped a pin through the already drilled holes, and welded it to the top of the angle iron
6. Next I cut the 2x2 tubing to three lengths about three inches shorter than the 42" forks, slipped a full-length chunk of rebar into each piece to add stiffness and welded each in front and rear, cut the ends so I could weld them shut with a taper, aligned the lengths equal distance from the forks and each other and welded them to the angle iron. They look a bit like this but only three of them and where the tubing goes across the back is the angle iron attaching point:
That's it. Really easy and didn't cost much in materials or time. This is a load of pine needles/pine straw (for the southerners) so you can see it works well. Slips on and off in a trice and is light-weight.
   / Bucket attached pallet forks #15
How much did you pay for your quick attach system to use your forks that you are no longer going to use because you want to clamp forks to your bucket?? ;)
I think you already know the answer is it will take you longer to clamp the forks on by hand than just dropping the bucket and picking up the forks.
Have you ever considered, or is it possible, to put small actuators on the quick detach levers? Like linear actuators or small hydraulic cylinders.
On my PowerTrac it came with a quick attach system that operates hydraulically. I just set the bucket down, pull a valve near my knee and back away from the bucket. Drive over to my forks, pick them up, push the lever and lock it in. It litterally takes me less than 15 seconds to change implements without getting off the tractor. :thumbsup:
I'm surprised no one has gone after the niche market of quick attach automation conversion kits. Are there kits out there?
   / Bucket attached pallet forks #16
Kubota has it, I think its 1500. dollar option my dealer says nobody buys it . He gave one to a guy that buy alot of stuff there
   / Bucket attached pallet forks #18
YEOWCH!
Is it a standard skid steer quick attach or a Kubota proprietary quick attach on your machine? Got any pictures of the levers?
Do you have 3rd function hydraulics for a grapple on the FEL?
   / Bucket attached pallet forks #19
   / Bucket attached pallet forks #20
So it would take you about 30 seconds to disconnect hoses for the grapple and drop the bucket.
I have a similar deal on my Power Trac when I change powered impelements. Mower, brush cutter, or power angled snow blade. Just two hoses on quick disconnects.
One thing about those drive up forks.... what keeps them from swinging up if you angle the bucket down too far? Can you get the tips under stuff and pry down with them like you can with dedicated forks?
2006 MACK CV713 KILL TRUCK (A50854)
2006 MACK CV713...
2004 Club Car Precedent Electric Golf Cart (A50860)
2004 Club Car...
2015 INTERNATIONAL 4300 26 FT NON CDL BOX TRUCK (A51219)
2015 INTERNATIONAL...
Misc Items (A50860)
Misc Items (A50860)
2007 TRANSCRAFT 48X102 FLATBED (A50854)
2007 TRANSCRAFT...
2018 Chevrolet Tahoe SUV (A50324)
2018 Chevrolet...
