brush cutter dimensions
   / brush cutter dimensions #1
Oldstuff
Missouri
'63 Ford 2000
I'm in the process of upgrading to a tractor that has a FEL (not quick disconnect) but am trying to determine if it will fit in my shed with a bruch cutter on it. I know the exact distance from the front of the FEL to the holes in the lift arms at the rear and it looks like my brush cutter (King Kutter) is 8 inches toooo long. I have looked at a couple of websites to determine the physical size is in length and some do not list the length.
Does anyone know of one brand being shoerter than others?
Thanks- Oldstoff
   / brush cutter dimensions #3
Did you addon deck wheel?
   / brush cutter dimensions #5
King Kutter? What size? I can measure my 5 foot one when the rain stops.
wirlbird, it is a 5 footer- I cannot check myself because tractor is 160 miles away
   / brush cutter dimensions #7
Just went out and measured my 5 ft wallace , Right at 8 ft from tailwheel to pins,
   / brush cutter dimensions #8
Mine was a little tricky to get to due to where I have it stored but looks like 78-80 inches. Definitely under 7 feet.
Thanks wirlybird
2014 MACK CHU TANDEM AXLE DAY CAB (A51219)
2014 MACK CHU...
2015 International DuraStar 4300 Street Sweeper Truck (A50323)
2015 International...
2016 Ford F-150 Pickup Truck (A49461)
2016 Ford F-150...
2000 Dnya RGN (A49461)
2015 Hamm H7i VR-3 Single Drum Vibratory Soil Compactor (A49346)
2015 Hamm H7i VR-3...
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A51039)
2007 Freightliner...
