Broken grease zerk extractor tool recomendation?
   / Broken grease zerk extractor tool recomendation? #1
Fallon
Super Member
Parker, CO
Kubota L4060hstc, formerly L3200hst
Found a grease zerk sheered off of one of my tie rod. Trid using a chisle to get a bite & tap it out, but no go. I could drill it out, but the one bit close in size is a bit dull. I've ran into a few busted zerks recently not to mention some other bolts & what not. Any good recomendations for bolt extractors?
I was looking at the $32 Irwin 10 piece kit, but am now thinking I might as well get the big kit for the other sizes I'll probaby eventually need.
IRWIN HANSON Screw Extractor and Drill Bit Set, 35 Piece, 11135 IRWIN HANSON Screw Extractor and Drill Bit Set, 35 Piece, 11135 - Jobber Drill Bits - Amazon.com
Thoughts? Suggestions?
   / Broken grease zerk extractor tool recomendation? #2
tractor supply sells a tool down here in florida with zerks and to retap the hole.might want to check with them online
   / Broken grease zerk extractor tool recomendation? #4
I typically just use standard easy-outs. Usually because I have a ton of them in the cabinet.
Those irwin ones that have the large hex drive and finer teeth....they work well too.
I cannot attest to the quality of the drill bits, but see that irwin kit comes with left handed bits as well. Thats usually step one when removing broken bolts, as alot of times thats all thats needed. But have never needed to drill to remove a grease zerk....singe they are hollow already. Just pick the spring out if its still in there.
For real difficult stuff, I do like the square profile extractors as well that Curly Dave mentioned.
I saw several Lincoln branded ones on Amazon for around $10 each. Unfortunately they are all SAE & the Kubota is Metric (M6 for the zerk threads). I assume the extractor might work, but not the tap & driver part.
2008 Ford F450 (A49461)
2008 Ford F450...
2008 Ford F-250 Reading Service Truck (A50323)
2008 Ford F-250...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
Wells Cargo Enclosed Trailer (A50324)
Wells Cargo...
2005 WINNEBAGO WORKHORSE W22 RV (A50854)
2005 WINNEBAGO...
