Brewery help
   / Brewery help #11
<font color=blue>What else do you suppose we agree on?</font color=blue>
How about "live a good life", but for goodness sake don't analyze why!
Chuck
   / Brewery help #12
This system is similar to mine, except that I use a 48qt ice chest for the mashtun, and have a regular old coiled wort chiller. Five of us built the same systems about 12 years ago, based on what one of my friends had seen and used with another buddy.
I like the ice chest for a mashtun, as it holds temp really well. It is also shorted, so the overall height of the system is shorter. My mashtun has two copper pipe maifold, witha lot of sltis made with a sawsall. One manifold is on top, and acts as a sprinkler. The bottom manifold takes the runoff out to the boiling keg.
My chiller works fine, and is easy to clean. When I get real fancy, I put my old 5gal wort chiller in a bucket of ice water. I connect the hose to it, and then another hose over to the chiller that's in the wort. It works great that way.
By ez-mash screen, do you mean that screen filter thing that Jack Schmidling sells? I think that tool takes too much of the sweet wort from one spot, instead of the entire grain bed.
The lower manifold in my mashtun runs basicall three pipes along the entire length of the grain bed. So, I pull sweet wort from the entire base of the grain bed; I think that works much better, but that is IMHO, as I have not tried other methods.
I think my manifold approximates what a false botom does, in a rectangular ice chest.
The system your buddy has is a great setup. I'm sure it works great. I think my mashtun probably is easier to work with, but either step should work just fine.
   / Brewery help #13
Robert,
Do you do a single temperature mash or do you get fancy? I was mainly wondering how you heat the mash if needed. Bleed off some wort, heat it and put it back? If I ever get around to it, I want to make a mash tun using an Igloo-type cylindrical cooler, probably with a manifold much like yours. Somewhere in my piles of stuff I have a nice list of the required plumbing fittings to do the job.
Chuck
   / Brewery help #14
Chuck,
I have done two step mashes. With enough grain for 10gal of wort, I can hit a second temp. But, it does tend to fill the cooler pretty full. If I were to build another mashtun, I would go for a bigger ice chest.
I heat the mash by adding additional hot water. It does thin out the mash, but it works ok.
One thing I like about using a rectangular ice chest, is that it is shorter than the cylinder type. I use 15gal kegs for mash/sparge water and boiler. The boiler sits up high enough that I can drain the cooled wort directly into a carboy that sits on the floor. As I make each step up towards the mash/sparge water heating keg, the system gets to be about 7' tall. To use a cylinder cooler type mashtun, it would be even taller. I'll have to borrow a digital camera and take a picture of the setup. I've been meaning to do that...
   / Brewery help
I understand the concern for portable propane in the basement. Our house is to new to blow to splinters. The set-up in the picture is in a friends garage. I am planning to be in our garage until I get the brewhouse done next summer. The brewhouse may actually be in the barn we're building, but I am kinda thinking I may do a stone, block and brick building about 14'x14'. I was figureing mostly to the soda containers. Then I get to make a tap area in the bar.
   / Brewery help
The cooler idea is what I was hoping for. If you had a picture that would be great. The owner of the pictured equipment says he has to have a small ladder to get into the upper barrel.
   / Brewery help
Forgot to mention that the ez-mash I was thinking of was about a 12" long x 1"dia. screen called the bazooka at homebrewheaven. My friend made his own screens and said it was a pain. The have a good looking false bottom at homebrewheaven, I think. I wasn't sure if going to the tube screen would be better. It makes sense that you would be better off drawing from the whole bottom since you sprinkle the water all acrossed the top.
   / Brewery help
I have seen a couple counterflow chillers at brewers websites. Don't know anyone that uses the the types I've seen. The copper submersible ones seem to be the easiest to clean. Part of me wants something easy and part of me wants something pretty cool.
   / Brewery help
Chuck, parts lists and would definately be helpful.
   / Brewery help #20
I know people use the screen type setup, but I think it brings the runoffs from a considerably smaller, concentrated area. I would look at having a piece of slotted tubing coiled up or something so it would fit the bottom of the container.
I'll bug a friend to borrow a camera... I've been meaning to get pictures... It's a pretty simple manifold.
My system is still tall. I use a short ladder to get to the upper keg when filling. I certianly wouldn't want it any taller.
2022 Club Car Tempo Cart (A55852)
2022 Club Car...
2023 Kubota M5660SUH Compact Utility Tractor with LA115-4 Loader (A56435)
2023 Kubota...
2012 Chevrolet Silverado 2500HD Enclosed Service Truck (A55973)
2012 Chevrolet...
30in Hydraulic pallet Forks Skid Steer Attachment (A56857)
30in Hydraulic...
60'' SKID STEER BUCKET (A56857)
60'' SKID STEER...
DEUTZ MARATHON...
