Branson 4720
   / Branson 4720 #1
ucfd070
Ga
none
I have a 2005 Branson 4720 with the Ag tires. I have found a set of Kubota 6060 turf tires and wheels.
size These are new take offs from a Kubota 6060. Front size is LSW 305 R 343 and the rear size is 610 R 470.
My question is will the wheels fit my tractor? are the bolt patterns the same? 8 lug. or are these too wide?
I'm tired of tearing up my pastures.
   / Branson 4720 #2
First off you need to measure the circumference of you rear tires and of your front tires. Determine the ratio between the two and see if the ratio is the same for the Kubota tires. Then you will need to measure the bolt circles from each to see if they match.
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
HUSKY 135 PSI AIR COMPRESSOR (A50854)
HUSKY 135 PSI AIR...
2006 Ford F-150 Pickup Truck (A48081)
2006 Ford F-150...
2015 VOLVO VNL TANDEM AXLE SLEEPER (A51219)
2015 VOLVO VNL...
2015 VANTAGE TRAILER CRUDE TRAILER (A50854)
2015 VANTAGE...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
