Branson 4220i injector pump
   / Branson 4220i injector pump #1
marcallenssi
Brunswick, Ga.
Branson 4220i
I have 2007 Branson 4220i that quit running today. have fuel to the pump but no fuel out of pump to injectors. dealer says new pump is $1000 for part only. Anyone know where I might find a better price?
   / Branson 4220i injector pump #2
have yours rebuilt
   / Branson 4220i injector pump #3
see you are in brunswick ga please call a company in augusta called testmaster phone number 706-790-8828 they are very reputable and may have another shop closer you i think they have a shop in savannah you will need the model number and all other numbers on the id tag they should be able to build yours at better price i had to have 1 built this week for older 7.3 powerstroke was only 385.00 parts and labor so rebuilding if possible is a money saver and you get back the original part good luck
   / Branson 4220i injector pump #4
If inj pump is electrically controlled then I suspect that the fuel control solenoid is the problem not the actual inj pump.
2003 MACK RD6885S T/A DUMP TRUCK (A51406)
2003 MACK RD6885S...
Vermeer SC802 (A50322)
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
2006 GMC 4500 Bucket Truck with Altec AT200 - 34FT Working Height (A51039)
2006 GMC 4500...
2 Vintage Metal Signs (A48081)
2 Vintage Metal...
TEST BID LOT (A50775)
