Grading box blade
   / box blade #1
countonjoe
I am looking at buying a First Choice brand box blade. Is this a high quality brand implement? I own a John Deere 2020. It is only 2 wheel drive but a 54 horse diesel. Will I have any problem pulling a 6 foot box blade once loaded with dirt? Should I consider the 5' model for this reason? Also will rear wheel weights help or hinder the drag?
   / box blade #2
I think there are better/heavier duty box blades out there than the First Choice, but you will pay more. The JD should handle a 6 foot box blade fine. Rear wheel weights will help with traction when using the box blade.
   / box blade
thank you for the info. What brands might be heavier duty than First Choice?
   / box blade #4
I have a Bush Hog brand 72" box blade that I would consider to be pretty heave duty (although probably not the absolute heaviest). I think the Howse brand is about the same toughness as First Choice. Can anyone back me up on that?
Lawrence
   / box blade #5
Woods makes some heavy duty box blades. I was shopping for one a little over a year ago. From memory, I believe the woods 6' heavy duty offering weighed over 1000 pounds, and cost over 1000 bucks. Problem is, I was also shopping for a bush hog at the same time and I could have prices and or weights mixed up.
   / box blade #6
When I was shopping for mine I looked at a Landpride that was extreamly well made, and, as you would think, very expensive. Needless to say I went with something much lighter, but appropriately sized for my tractor. Please let us know what you wind up buying.
   / box blade
Thanks to this great forum and the knowledgable men posting here I am leaning toward the 6' Midwest. Should have a price tomorrow and will make a decision then. Will let you know. This website was a great find.
   / box blade #8
I just picked up a 7' Land Pride box blade today. (BB2584 see attachment) It seems well made and has a hinged backfill blade to help when smoothing. I will be using it with my TC-40D
   / box blade #9
I have been using a 72" First Choice/Midwest box blade for about 2 years now. It's a good sturdy unit that has no trouble with roots, rocks or anything else I have encountered. I would consider it a medium-duty implement. All the 3 pt structure is solid and not susceptible to bending under reasonable use... quite a step up from some of the low-end units out there. The biggest issue is lack of weight... it's probably only 5-600 lbs, vs. 1,000 or so for the real heavy-duty units. I strap on a few sacks of concrete, but that's not a good solution and sometime I'll rig up a better set of additional weights. Even so, it works fine in soil and gravel. If I were using it commercially, the HD type would be better, but this has my needs covered.
Incidentally, I think First Choice and Midwest are no longer associated, but Midwest is selling on their own plus some private branding.
   / box blade
How does it hold up with roots, rocks etc?
2021 Liebherr L556 (A52128)
2021 Liebherr L556...
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
1999 24DTA pintle hitch trailer (A52128)
1999 24DTA pintle...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2016 Dodge Journey SUV (A50324)
2016 Dodge Journey...
UNUSED AGT QUICK ATTACH AUGER SET (A51244)
UNUSED AGT QUICK...
