Boomer 24 routine maintenance
   / Boomer 24 routine maintenance #1
TheMan419
Indiana
New Holland Boomer 24
Ok silly question..... manual says fuel filter change (among other things) at 300 hours.
Do I need the element for like $15 or the whole assembly which runs $110?
Note that I want to do it right so spring the $110 is fine if I need to. Just don稚 want to if I don稚 have to.
   / Boomer 24 routine maintenance #2
Just the element, and watch for the O-rings when you disassemble. Put a bucket under it and let some fuel flow through to flush the line.
Thanks!
   / Boomer 24 routine maintenance #4
Also ensure you bleed the air out of the system when finished replacing the cartridge...usually a vent plug on top of the filter assy....crack it and get fuel flowing and let it continue till all the bubbles are out.
UNUSED PABREAK CR720 - 74" VIBRATORY ROLLER (A57193)
UNUSED PABREAK...
John Deere Z997R (A56469)
John Deere Z997R...
2018 Ford Fusion (A56859)
2018 Ford Fusion...
2 Cubic Yard Dumpster (A55851)
2 Cubic Yard...
40' CONTAINER (A57192)
2016 Ford F-450 Flatbed Utility Service Truck (A56858)
2016 Ford F-450...
