bolckage in mf 220 back hoe?
   / bolckage in mf 220 back hoe? #1
geoloz
mf 100 mf 220
Help please. I have a MF 220 backhoe that blew the hose on the left side of the conrol gang as you sit to operate the hoe. I replaced the hose, then the return pressure plate on the gang reptured. I have now replaced that but want to know why the pressure builds so high before I continue. When the selector valve is set to operate the hoe, the engine starts to strain, as if there is a restriction. Any help is appreciated thanks
FYI here is a picture of blown pressure plate!
   / bolckage in mf 220 back hoe? #3
What you are describing sounds like a line is connected improperly. Did you have to remove more lines to replace the one that blew?
Is this a backhoe one that you just remounted to the tractor? If yes I would again suspect line connected improperly.
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A51692)
2003 International...
2012 International (A55973)
2012 International...
2018 CHEVROLET SILVERADO CREW CAB TRUCK (A52706)
2018 CHEVROLET...
2024 78in Hydraulic Brush Grapple Skid Steer Attachment (A55851)
2024 78in...
1999 Vermeer SC505 Walk-Behind Tracked Stump Grinder (A55851)
1999 Vermeer SC505...
