bodywork sheetmetal work ?
   / bodywork sheetmetal work ? #11
Their exists a tool calles a shrinker that does what you want.
It is like two hardened steel jaws that grab and pull the metal thereby creating a rounded corner in a folded piece of flat sheet.
You'd basically make the major fold over and then using the shrinker pull the metal to create the rounded corners in the folded metal.
I had one and the learning curve was easy.
Worked best on aluminum and brass but OK on steel.
with a shrinker you should leave extra metal to trim off the jaw marks
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
Heavy Duty Solid Steel Skid Steer Mounting Plate (New/Unused) (A59225)
Heavy Duty Solid...
40' x 20' All Metal Carport (New/Unused) (A59225)
40' x 20' All...
Kubota U55-4 (A57148)
SKID STEER ATTACHMENT AUGER (A58214)
SKID STEER...
(3) BUG REFLECTORS IN BOX (A58374)
(3) BUG REFLECTORS...
