Bobcat CT 235 Not Starting
   / Bobcat CT 235 Not Starting #1
dean7777
darlington, md
bobcat ct235
Bobcat CT 235 cranking and turning over, but will not start. Replaced air and fuel filters and fuel is getting to the injectors. Any suggestions?
   / Bobcat CT 235 Not Starting #2
As I'm sure you are aware since you in the Kioti forums - the Bobcat CT series CK series kioti.
There are several threads dedicated to issues exactly like yours and most of them point to an electrical issue of some sort.
Here are a couple I found that have some good troubleshooting info & pictures that should get you started.
Bad fuse on Stop Solenoid
http://www.tractorbynet.com/forums/kioti-owning-operating/353649-ck35h-wont-start.html
Bad Key Switch
http://www.tractorbynet.com/forums/kioti-owning-operating/360507-kioti-ck30-cranks-but-doesnt.html
Bad Relay
http://www.tractorbynet.com/forums/kioti-owning-operating/349919-ck27-wont-start-2.html
Hope this helps & good luck.
Bad Key Switch
Bad Relay
Thank you very much!!!
   / Bobcat CT 235 Not Starting #4
You're very welcome. If none of these help just keep searching this forum for starting issues for other culprits.
Once you get it fixed, be sure to come back and let us know what you found.
Good Luck.
Good Luck.
Will do,
I have checked the power relays on the firewall and they are good. Very frustrating, will probably have to take it to the shop.
   / Bobcat CT 235 Not Starting #6
Did you check the stop solenoid fuse? Its hidden in the fuse box up under the dash RT side - main fuse box number 8 position. Check your owners manual page PM 34
Yes I checked the solenoid fuse, it was good.
   / Bobcat CT 235 Not Starting #8
Does the stop solenoid click when the key is turned towards start?
   / Bobcat CT 235 Not Starting #9
Dean, If the engine cranks at a good rate, check the glow plugs are getting power at the bus bar while cranking and ensure the stop solenoid is truly retracting (and staying retracted) when the key is on. If that all checks out, then check that the injection pump rack is free to move.
Case SV280B (A53317)
2005 EZ-GO Cart (A55853)
2005 EZ-GO Cart...
TANK MANIFOLD (A55745)
2015 GMC Terrain (A56859)
2015 GMC Terrain...
UNUSED RAYTREE RMRB72-72" HYD POWER RAKE BUCKET (A57193)
UNUSED RAYTREE...
6' ROTARY MOWER 3PT W/ FULL SHAFT (A57192)
6' ROTARY MOWER...
