Block Heater Location, BX 2200??
   / Block Heater Location, BX 2200?? #12
Try one of the major auto supply stores. Around here, AutoZone is one of the big ones. They usually have all kinds of odd-ball sized tools for car parts. If I remember correctly, the 17mm is a pretty common size for cars. Most of the places have a "borrow" (if you buy parts needing the tool) or rental for them. Worst case, they usually are excessively priced.
Kevin
   / Block Heater Location, BX 2200?? #14
Tom: ...The 17mm socket is a 3/8" drive and was purchased about 10
yrs. ago to drain a tranny on a VW beetle. I believe I got it at Sears? or
in (metric tool section- $5/$7) of an auto parts store. I mentioned in an earlier post to get a 1/2" drive or
it will break. If you look closely at the last pix, you'll see where the socket
had to be welded to the (3/8" to 1/2") adapter because it was about to
break off the 3/8" drive shank. Otherwise if you can locate a 1/2" drive
17mm socket you are good to go. /forums/images/graemlins/smile.gif RayBee
   / Block Heater Location, BX 2200?? #15
Grainger has one made by Proto (Stanley) for $13.86 catalog price.
   / Block Heater Location, BX 2200?? #17
My Tool Store has one for under $9 made by S-K
So they should be available in a few locations if Proto and S-K make them.
   / Block Heater Location, BX 2200?? #18
Tom,
Around here anyone can buy from Grainger. But if you are a business you can get a better price. I own a HVAC business and we get around a 25% better price. Doesn't come out to much on a tool that runs around ten or fifteen bucks.
Murph
   / Block Heater Location, BX 2200?? #20
I just stopped by my Kubota dealer to order a block heater for my BX2200. One of the mechanics showed me where the plug was located. He said that he recomends using a short bolt with two nuts locked on the end to get the plug out. He said that will save me from buying a allen socket that I will only use once. I plan to give it a try. He didn't know what size of bolt. A bolt and two nuts should be cheaper that a allen socket.
John
Champion Gas Powered Auger (A57454)
Champion Gas...
2025 AGT YC-32G Saw Mill (A53317)
2025 AGT YC-32G...
2004 PSI M413XT Motor Grader (A56857)
2004 PSI M413XT...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
2017 John Deere 1025R Tractor - 626 Engine Hours (A56436)
2017 John Deere...
2009 Bruton T/A Enclosed Livestock Trailer (A55973)
2009 Bruton T/A...
