Bob_Young
Veteran Member
- Joined
- Jul 5, 2002
- Messages
- 1,244
- Location
- North of the Fingerlakes - NY
- Tractor
- Ford 4000; Ford 2000(both 3cyl.);JD40; 2004 Kubota L4300; 2006 Kubota B7610; new 2007 Kubota MX5000
Finally got to see the new Woods BH90-X mounted on my L4300 today. Was surprised to see how far it hung out the back and how close to the ground it was. Didn't see a departure angle listed on the website specs but ASSumed it was around 18 degrees...as that's what Kubota lists for its older designs. WRONG! It's 15 degrees.
I'm going to have to play some games to load that thing on my 20' Big Tex pipe trailer. Trailer deck is 20" above the ground sitting level and the rear gate/ramp is only 50" long.
Planning to jack up front of trailer until back of deck is about a foot off the ground. That should give me a little less than 15 degrees slope at the gate. I'll hafta chock and jackstand the heck out of it to avoid problems. This will have to do until I can buy some heavy duty ramps and weld ramp anchor rails to the back of the trailer.
What you get when you ASSume...
Though even 18 degrees would've been a problem with my setup.
Bob
Bob
