Best uses for chlorinated brake cleaners
   / Best uses for chlorinated brake cleaners #21
Why would you use chlorinated brake cleaner for anything, though? Non-chlorinated works great. When you have the choice to use less harmful products for the health of the planet and your own body, be an educated consumer and make the right choice.
What exactly happens to the aluminum when chlorinated brake cleaner is used? It would seem that the brake cleaner, since it dries quickly, would have little chance of attacking the aluminum.
Anyone have insight to this issue?
Where it really causes damage is when it doesn't get the chance to evaporate quickly, like when it is sprayed into a blind hole. Then it can really start to work on the aluminum and cause corrosion similar to rust. Sometimes the chemical reaction can be dramatic, with foaming stuff coming out of the hole and the threads in the hole pitted and visibly damaged. Sprayed on surfaces it is not that big of a deal but oftentimes machined ports have tapped holes in them.
Eric
The reason I wrote the original post was to say when and why I would use them. The non-chlorinated brake cleaners work very well for what they are made for. When I use chlorinated brake cleaners it is not for cleaning brake components. I just use it for cleaning non-aluminum parts when using anaerobic adhesives, like thread locker adhesives, for example Loctite. I feel that the minimal use of these solvents and the dangers they pose is outweighed by the utility of these types of solvents. The types for sale now cause minimal damage to the environment while at the same time help to keep mechanical components from coming apart. It is certainly a judgement call on my part. I think these types of solvents should only be used for fasteners and cylindrical fits and the like when anaerobic adhesives are being used. There are less harmful but also less effective solvents available.
Eric
2010 Acura TL3.5 Sedan (A48082)
2010 Acura TL3.5...
2015 MACK GU713 (A50854)
2015 MACK GU713...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
1981 Case 245 2wd tractor with bushing (A51039)
1981 Case 245 2wd...
2022 BANDIT 2550TK STUMP GRINDER (A51242)
2022 BANDIT 2550TK...
2014 Ford F550 Crane Truck (A50323)
2014 Ford F550...
