Best PHD for CUT?
   / Best PHD for CUT? #1
donn12
Platinum Member
Great Falls Virginia
B2920 TLB turfs and loaded ags
I have a Kubota B2920 and thanks to all the rain my fence is pushed over out back. What is a decent PHD? I would like the best value not the cheapest. Thank you!
   / Best PHD for CUT? #2
Donn, if you're only going to use a PHD occasionally, even a "rude and crude" one like I bought at Tractor Supply a long time ago will probably last forever. If you have very hard or rocky soil or figure to go into the fencing business, maybe a better grade PHD would stand up to hard duty, but otherwise, most all of them work about the same.
   / Best PHD for CUT? #3
i you want a real good digger get a bushhogg with a bear claw on the auger.you wont be dissappointed.
   / Best PHD for CUT?
I was thinking about the TSC unit - looks pretty good!
   / Best PHD for CUT? #5
Most PHD now a days use "Comer" or other Chinese gear boxes.With the exception of probably "Danuser and Beefco".
I think those TSC PHD are Speeco's.
Some auger lenghts 42" others 48".
TSC PHD come shipped dry,so whichever or whatever PHD you go with always check oil level(80/90) regardless of what dealer or salesman/woman tells you !
Make sure unit complete before you leave place of purchase(pins,pto shaft,guide bar if equip for one,protective covers, etc).
Boone
   / Best PHD for CUT?
I bought the county line from TSC - cant beat it for $420! I also got a 9 and a 12 inch auger. It seems well built enough for everything I will need it to do (I will not be earning a living with it).
   / Best PHD for CUT? #8
You might also consider renting a PHD, unless you foresee more usage in the future.
   / Best PHD for CUT? #9
I just sold my TSC/Speeco that I have had used on larger tractors than I am using now. It is a perfectly fine nice PHD, but it does not fit my current JD 2520 CUT - I could never get it high enough out of the ground the way I wanted. This is due to the curved boom end. I have purchased the ETA (nice folks from my experience and I am in NC) Compact PHD - it is now on its way. Nowadays, there are several PHD on the market that best fit CUTs. Scott H.
   / Best PHD for CUT? #10
I bought a Land Pride with my B2920 (smallest one, PD10) and have quickly learned I 1.) they are way overpriced, and2) the smallest one doesn't dig deep enough (factory auger). I now wish I had went ahead and got the TSC model....unless your doing commercial work or fencing 1000 acres, it plenty stout, and a heck of a lot cheaper.
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
FUEL CELL (A58216)
FUEL CELL (A58216)
2017 Elgin Broom Badger Sweeper, Kubota Turbo Diesel Engine, High Dump, Dual Tilted Gutter Brooms... (A59076)
2017 Elgin Broom...
2020 DRAGON ESP...
2004 Freightliner FL60 Ambulance (A56858)
2004 Freightliner...
IRMC High-End Massage Chair (A57149)
IRMC High-End...
