Best method to bush hog?
   / Best method to bush hog? #1
Slippy
Veteran Member
Ohio
Mahindra 6000 4wd; IH x2; NHTC40DSS; International 1086; JD 5115M
What is the text book and best method to bush hog? I am cutting alot of open fields on rolling terrain. I have tired splitting a bock of field which allows me to keep cutting in the same direction each pass. I have also tried it with each pass going back against the grain. I have noticed that when I go back against the grain, the grass I pushed down with my wheels is stood back up by the front of the cutter. It does slow me down a little. I have a 10' pull cutter that is obviously wider than my wheels. Any thoughts?
   / Best method to bush hog? #3
well my father always tought me to never go back the opposite direction when brushogging, like go in circular squares in the field instead up doing a 180 turn and going back down the same row. the reason for this is that in heavy grass and briars, or especialy brush, all the stuff will be laying down towards you and much more likely to poke a hole in the radiator. on the old fords the radiator was not well protected so you had to be carefull. of course twice we still managed to put a hole in the radiator, but im sure it would have been alot more often if i hadnt followed his advice.
2021 Cat 259D3 (A53317)
2021 Cat 259D3...
2015 Ford Fusion Sedan (A55853)
2015 Ford Fusion...
CATERPILLAR 108" WHEEL LOADER RAKE (A52707)
CATERPILLAR 108"...
UNUSED PABREAK BC352 - 72" HYD BRUSH CUTTER (A57193)
UNUSED PABREAK...
2022 TAKEUCHI TL12R-2 SKID STEER (A52707)
2022 TAKEUCHI...
UNUSED FUTURE 36C STAD ON SKID STEER (A57192)
UNUSED FUTURE 36C...
