Best Inexpensive Grease Gun
   / Best Inexpensive Grease Gun #11
The John deere grease gun (#TY26517) I bought when I bought my 5075E has been excellent. I have several other grease guns that do the job, but none of them are as nice as the JD one I bought to use Polyurethane grease in. BTW people try to sell this grease gun online for almost $40. It was like $24 or somewhere in that range at my local JD dealer. Also most of the prices for the JD Polyurethane grease are about doubled online compared to what my JD dealer sells it for.
   / Best Inexpensive Grease Gun #13
I found a seezed up lever action grease gun in a huyndai loader about 10yrs ago. Its been a great old girl. I do have a lincoln too.
Yes you read that right. A seezed up grease gun....just imagine what the loader looked like.
   / Best Inexpensive Grease Gun #14
I bought this Lincoln and it works very well. I am not a fan of the air power or battery grease guns. I only use it once a month or so, maybe if I did it more I would change my mind.
Amazon.com: Drake Off Road Lincoln Lubrication 1134 Heavy Duty Pistol Grip Grease Gun with Whip Hose and Rigid Pipe: Automotive
I also (due to feedback from here) bought the Lock-n-lube which is fantastic!
Amazon.com: LockNLube Grease Coupler locks onto Zerk fittings. Grease goes in, not on the machine. World's best-selling original locking grease coupler. Rated 1, PSI. Long-lasting rebuildable tool.: Automotive
   / Best Inexpensive Grease Gun #15
I've got two 'hand grip' style. The first one I bought from my local auto parts shop; it works fine (after figuring out the knurled adjustment tip*... thanks TBN!) but the JD grease cartridges didn't fit. And those cartridges are very convenient.
So I bought a JD branded one that did fit the cartridges.
I've never had a problem with squeezing the grease.
* don't fully disassemble the knurled tip to 'see how it works' as the spring inside will shoot across the workshop and you'll spend hours looking for it!
Buy one of those magnets on the end of a stick and use it to pick up nails in a construction site. I've found lots of small parts that shot across the shop and were presumed gone forever. Very easy.
14ft Tri Axle Homemade Trailer (A57453)
14ft Tri Axle...
2019 INTERNATIONAL LT625 (A58214)
2019 INTERNATIONAL...
SKID STEER ATTACHMENT AUGER (A58216)
SKID STEER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A56436)
2023 Kubota...
2020 DRAGON ESP...
