Best Garage Heater?
   / Best Garage Heater? #11
Barry,
How much volume does your garage have? Reason I ask is the old "heat rises" issue which can render an otherwise good heat source pretty useless, because it's heating a huge loft. If the volume is reasonable (12-14' ceilings), I have beeen quite happy with the indoor-approved kerosene heaters. These are the kind you get from TSC, WalMart, etc. I have used them for years, starting when I was living in CT with pretty cold winters. A 23,000 BTU/hr Dyna Glo runs ~$120 at TSC, and it will burn its 1.9 Gal kero fill over a 12 hr period. A pair of them in a 2-car garage provides a very high level of comfort. Of course, you can get a single higher BTU model, too. I like the flexibility of 2 lower rated heaters, using one or both depending on ambient.
Just like when you use them inside the home, you need to be sure they are in an open area, away from flammables and combustibles, etc., etc. I start the heaters about 1-2 hr before I am going to work. That's about the only drawback--they don't make instant heat. They are however, very safe and efficient. I also have a Carbon Monoxide monitor plugged into a garage outlet and test it regularly. It has never alarmed with the kero heaters in operation. Nice thing about these heaters, is that when the weather warms up, you just put 'em away. No installation, no plumbing, low initial cost, and low (relatively!) ongoing energy costs.
I like the idea of the radiant floor heat. Maybe someday, when I build the dream garage for the 425, the 1430 and the 1850 /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Thanks all,
great suggestions. I'm leaning toward the Pro-Com 25,000 BTU Propane infrared radiant heater, Mr heater products look good too. Also a regular kerosine heater, be it one or 2 per TracDocs suggestion.
All good in case the electric heat goes out during a storm. We have a propane fireplace upstairs, but no backup downstairs it at least would help . May be a good way to kill two terrorist with one bullet. I Have not really compared the price of Kerosine verses Propane. Need to check into that /forums/images/graemlins/shocked.gif
Tracdoc,
Haven't measured the square footage, but it is just a standard two car garage with insulated walls and about 10 foot ceilings an attic and insulation above. Thanks I was considering regular kerosine heaters also. /forums/images/graemlins/shocked.gif
Thanks for your input Robison,
Something to ponder, maybe some day. /forums/images/graemlins/smirk.gif
Thanks ontheweb,
They look like good heaters. Little more than I want to spend right now. Rather save the extra $$ for more PT goodies. /forums/images/graemlins/smile.gif
   / Best Garage Heater? #16
Here is the heater that I use:
Click here for link
Many people don't like electric, but the fuel delivery and storage is easy. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Since I only use it when I'm working on something, the initial low cost was a consideration.
It keeps an 2-car garage (2 uninsulated walls, 2 common to the house, and house above) at 65 degrees when it's about 10 degrees outside.
Obviously, extra wiring & breaker is needed.
Mark H.
EDIT: Shortened long link.
   / Best Garage Heater? #17
I just bought the Pro-com 28,000 BTU Blue Flame heater (Propane) for my new shop ( and the PT's new home /forums/images/graemlins/wink.gif). I haven't installed it yet but it looks like a nice heater.
Looks like a good heating solution Catsco, only thing is I wanted something to double or bring into the house to help out in case of a power outage during a winter storm. I have electric central heat. Thanks for the link though. /forums/images/graemlins/ooo.gif
Great Highridge,
When you gonna hook that puppy up? Let us know how it works. /forums/images/graemlins/smile.gif
   / Best Garage Heater? #20
I have an unheated garage. its 26'd x 24w and 14h to the bottom of the rafters. When I need to work out there in the winter, I fire up a 150,000 btu kerosene salamander type heater then go back in the house for a cup of coffee. I place it toward the back of the garage with a window opened for fresh air intake and leave the garage door raised about 6-8" for cross flow. I also have an exhaust fan above the rafters to get rid of fumes. (good ventilation is a must) After 15-20 min. the garage is warm enough to work in short sleeves. Its portable, runs on 110V and the 7 gal. tank will last me almost all day if needed and I just unplug it when I'm done. Ive also used it to unthaw frozen pipes under doublewide / modular houses in about the time it takes to drink your coffee. Best of all, prices are around $300 or less for a good size unit.
METAL STORAGE RACK (A52708)
METAL STORAGE RACK...
2016 Chevy caprice (A55788)
2016 Chevy caprice...
PALLET OF MISC HOSE & PIPE INSULATION (A58374)
PALLET OF MISC...
2021 Ford F350 XL (A57148)
2021 Ford F350 XL...
1996 International Water Truck with a Caterpillar Engine (A56435)
1996 International...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
