Been a member about a month now ..........
   / Been a member about a month now .......... #1
dayjd1
Hollis Center, Maine
TYM273
I find alot of info here but the new incoming or requested information seems to flow like molasses. Much slower than other types of forums that I have been a member over over the last 10 - 15 years. Maybe it's just because the TYM tractor is not that popular here in the U.S Maybe a question to the main forum would get much more responses.
   / Been a member about a month now .......... #2
I doubt it. A lot of us just look through the days posts, not the individual threads.
   / Been a member about a month now .......... #3
   / Been a member about a month now .......... #4
Me also . What is your requested information ?
Installing a TYM snowblower to a TYM273
It is a front mount and also requires me to install a mid PTO which basically requires me to drop the pto bottom plate and bolt this new gear box in its place. My question ..... I need to drain the fluid from the pto transmission that I will be installing the new gear box to. Will I be draining transmission fluid or will it be hydraulic fluid I will be draining and replacing? Will any bleeding be required after this fluid change? Thanks, Bill
   / Been a member about a month now .......... #6
Most, if not all, tractors use only one fluid for transmission and hydraulics. I highly doubt there would be any bleeding involved afterward.
David, Thats what I was thinking but I'm relatively new to CUT so I sure do appreciate the info.
   / Been a member about a month now .......... #8
Not familiar with your tractor , but yes it's usually a common reservoir for hydraulics and trans . I'm guessing you don't have a manual . It will be obvious if it is 80/90 wt gear oil or if it is Hyd. fluid . Or it might be molasses .
   / Been a member about a month now .......... #9
It is Hydraulic Fluid,and the user manual recommend these 3 brands,RPM tractor hydraulic fluid or Textron TDH Premium,TDH Oil (Texaco),Chevron 1000THF.No bleeding required.
https://www.globenewswire.com/news-release/2025/05/08/3077245/0/en/Nerve-Calm-Complaints-Investigated-2025-User-Reviews-Tested-Verified.html
https://www.globene...
GENERATOR HOUSE POEWERED BY TWIN 12.7 DETROITS (A50854)
GENERATOR HOUSE...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER TRUCK (A51222)
2019 INTERNATIONAL...
2007 Mitsubishi Fuso FE84D 16ft Dovetail Flatbed Truck (A50323)
2007 Mitsubishi...
2022 Club Car...
P&H OMEGA 20-20 (A50854)
P&H OMEGA 20-20...
