Bed Former for Two Wheeled Tractor
   / Bed Former for Two Wheeled Tractor #1
ferrari99
Australia
Kubota BX2200, Ferrari 340
I would like to make a bed former for my 2 wheeled tractor. I have 4 x 17in plough discs. Does any one have any suggestions?
2.png http://http://www.ausfarmingco.com.au/main/page_bed_formers_dgw_single_row_bed_former.html
Thanks
   / Bed Former for Two Wheeled Tractor #2
You could make a double toolbar and put the discs wider closer to the tractor and narrower closer to the operator to move the soil higher. But will you have enough traction to pull it. Some like a roller behind the discs to smooth the bed top down rather than a chain. Let us know how you do with this.
   / Bed Former for Two Wheeled Tractor #3
+1 on the roller idea. If mounted rigid to the frame (as opposed to floating) it would act as a depth control as well as provide a firm seed bed.
Terry
Ended up getting a hiller/furrower. I did attempt to make one with discs though.
   / Bed Former for Two Wheeled Tractor #5
What you show is similar to what I used on my 4010 (18 hp 4wd JD) that I used to make raised rows with. Here're some pictures. Before I got the 4010, I made raised rows with a rotary plow by Gravely (picture below, too).
Ralph
   / Bed Former for Two Wheeled Tractor #6
Do you have a disk for your tractor..?? Here is a pic of a hill made with my David Bradley disk, with the disk's turned inwards. It took 3 rounds (6 passes) to make this hill I planted peanuts on. I also planted Bok Choy, onions, and peas in similar hills. It is set fairly close to center, and can be made wider.
I would like to take a roller and attach it behind the disk, to make a wider flat hill. like you are talking about. Will simply spread the disks further apart. And have in mind to make the roller adjustable, and fold up out of the way, so as to only roll on the last pass. Just haven't made up my mind what to make the roller out of.. I have plenty of 2" & 4" pipe. Thinking 4", as it will roll much easier, and more than likely stay on top of the loose dirt.
Misc. Hurricane Gates (A50860)
Misc. Hurricane...
Toro Z Master Mower (A50324)
Toro Z Master...
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A51039)
2000 John Deere...
2014 Ford F550 4x4 Bucket Truck with Versalift SST40 - 45FT Working Height (A51039)
2014 Ford F550 4x4...
2007 Peterbilt 335 Mickey AO-A Battery Truck (A50323)
2007 Peterbilt 335...
2009 Mini Cooper Clubman Sedan (A50860)
2009 Mini Cooper...
