May 11, 2012 / BCS 6hp Trans lubrication? #1 D drs48 New member Joined May 11, 2012 Messages 1 Location Mechanicsville-Pa Tractor BCS tiller Clutch and shifting is dificult....lost my manual...any recomendations for 20 year old BCS?....thanks.
May 31, 2012 / BCS 6hp Trans lubrication? #2 C cmyoung2 Platinum Member Joined Jun 21, 2010 Messages 534 Location North west NC mountains Tractor BCS 850, Kubota BX2230 w/FEL, mid mount mower, 41" tiller Kubota L3600 w/4-1FEL, Farmi winch Try reposting on the 2 wheel tractor forum, a little futher down the list. I would check the cable first, make sure it slides free and is adjusted correctly. Look through the 2 wheel posts and you can find links to the parts diagrams.
Jun 1, 2012 / BCS 6hp Trans lubrication? #3 JoeBuyer Banned Joined Dec 11, 2011 Messages 698 Tractor L5450 Are you talking about the high/low range or the forward/reverse?
Sep 30, 2012 / BCS 6hp Trans lubrication? #4 P PGC Member Joined Apr 9, 2012 Messages 45 Location Sonoma, CA Tractor BCS 853 (weights, 30" tiller, furrower, 40" mower, 20" mower, 1,200 lb trailer, scraper blade) Yep, there are some guys on the 2-wheel forum that know a TON about BCS.....I am not one.
Sep 30, 2012 / BCS 6hp Trans lubrication? #5 Buckgnarly Platinum Member Joined May 22, 2012 Messages 519 Location West topsham VT Tractor Kioti DS3510 80-90 gear lube for mine
