Battery Tenders..hmm
   / Battery Tenders..hmm #21
Have a couple.
My main one is permanently hooked up to my standby generator so that the battery is always 'ready to go'.
Has not let me down so far.
Others are used to maintain equipment batteries.
   / Battery Tenders..hmm #22
I have two Ctek ones. They are the ones I count on to Really work the battery and desulfinate it. They have done the job. The battery on my Steiner is now 8 years old. I also bought a battery checker. It measures internal battery resistance and can give you a state of capacity on a battery too. You input a rated CCA/amp hours and it will then tell you usable CCA's that are left in the battery. It's pretty impressive.
Here's a link to it on Amazon.
Steve
   / Battery Tenders..hmm #23
I use a B&D 25 amp battery charger with a maintainer and desulfonation function. I use it on the big diesel tractor battery and so far it works very well. The maintainer kicks on at about 90% charge and runs at 2 amps until full charge.
   / Battery Tenders..hmm #24
I think they only go into a full charge mode if voltage drops below 80%. 80%-100% the green light should be blinking though, as it's in a lighter charge mode maybe? Then when it hits 100% it goes into float mode.
Resting fully charged 12-volt flooded lead acid batteries are around 12.8-12.9 volts (some AGM are a bit higher, Gel are a bit lower). 12.0 volts is considered "dead", so 12.4 volts on a resting battery means it's about 50% charged.
Some chargers will cut themselves off if they have run for an extended time without bringing the battery up to a full state of charge. This is a safety mechanism so they don't keep trying to pump amps into a damaged battery. Even some "dumb" chargers have a timer built in. Some chargers can detect a load on the battery and warn you about that. A couple of my chargers will test for and detect a bad cell.
If you fully charge a flooded lead acid battery, let it sit overnight (with no load connected), and find that the voltage has dropped significantly below the 12.8 volt fully-charged resting state, it's likely you have a shorted cell and/or are heavily sulfated battery.
a couple of battery diagnostic tips:
If you let the battery rest for a day or two and it drops to 10.5 volts or so a cell is likely dead.
If the battery won't charge to more than 12.5 volts or so (assuming you have a decent charger connected) it's likely that the battery is sulfated. Note that some battery chargers will still show the battery as "Full" because the battery has stopped accepting charge. Connecting to a battery charger that has a desulfation feature might bring it back, though it can sometimes take quite some time to do so (weeks, if it is heavily sulfated).
2012 HYUNDAI  HL740-9 WHEEL LOADER (A58216)
2012 HYUNDAI...
1990 Electric Club Car (A56859)
1990 Electric Club...
2005 CHANDLER 500 BBL FRAC TANK (A58216)
2005 CHANDLER 500...
2003 INTERNATIONAL 9900I (INOPERABLE) (A58214)
2003 INTERNATIONAL...
New/Unused 14ft Bi-Parting Iron Gate (Elk Design) (A57454)
New/Unused 14ft...
2014 Freightliner 108SD Crane Truck, VIN # 1FVHG5CY3EHFL1495 (A57453)
2014 Freightliner...
