Band saw cutting fluid recomendations???
   / Band saw cutting fluid recomendations??? #31
I'm not talking about how many cuts but how often it gets used.
Will the soluble oil thicken up and spoil or do I just go to oil and be done with it? Then it could sit a month or two between uses and not be all gummed up.
Just wondering.
   / Band saw cutting fluid recomendations??? #32
Just wondering.
no it wount gum up it just begins to smell after a yr or so u drain it wash the tank with water then mix new if u use the soluble oil straight without mixing it with water it will last trimsol is the best but expencive a better choise it soluble synthetic its much cheaper.
   / Band saw cutting fluid recomendations??? #33
Ellis bandsaws use air... not liquids. I can't see messing around with extra oil / water-milk solutions getting spilled on the floor. I make a mess without this adding to the equasion.
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
2003 UTILITY TRAILER MANUFACTURER UTILITY TRAILER MANUFACTURER (A55745)
2003 UTILITY...
Killbros 260 Seed Conveyor (A56435)
Killbros 260 Seed...
Gas Pump Artwork (A55758)
Gas Pump Artwork...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2025 Swict 78in Tooth Bucket Skid Steer Attachment (A56857)
2025 Swict 78in...
