SpringHollow
Elite Member
My PT1850 PTO circuit is not working (does not turn the bush hog). Checked the voltage at the valve and it gets 12V when the pto switch is on (goes to 0 V like it should if you try to start the tractor). Checked with a clamp-on DC amp meter and both the positive and negative wires show about 3 amps. No clicking sounds when you turn the switch on and off. Sound like a bad solenoid? It seemed to magnetize though - piece of metal seemed to stick to it - I will have to check that more carefully.
Ken
Ken
