Bad Day at Block Rock - errrr - Make it Bad Year.
   / Bad Day at Block Rock - errrr - Make it Bad Year.
The bugs are winning. But at lest I slowed them down. There is some kind of a new bug every day. This AM it was what looked like a cockroach, except it had wings & was flying. landed on my leg. I tried to throw it down so I could stomp it. Bobby got in the way & it hopped off her & off the deck. Have had them in the bird seeds, from 2 different places. Never seen or heard of them in this area.
Got TV sounding a little better. Taped a hunk of Styrofoam over the speaker. Helped a little as long as AI am in front of it.
If I ever go to Tombstone, there is huge cast iron kettle. Take at least to strong people to set it in the truck. Plan to dig a hole, set an old barrel in it, pour cement around it. build big fire under it, once there is a big bed of charcoal under it will cook for hours.
Worked for a small company just off the end of the runway in Phoenix. They made custom cal rod heaters. Same thing is as in an electric stove. Just a lot longer. Some up to 30 feet long. First day on the job they sat me down at a punch press. It punched out fins that went on base board heaters. Made when business got slow. Second day foreman as me if I could weld. Just to gt away from the press I said yes.
At the end of the day he handed me a book on welding from some time in the late 30's. read the part that had something to do with my job. ( basically silver solder.). A few days later the owner came around & ask who was the welder, I didn't answer, but 1 of the others pointed me. I though oh crap I'm done. He came & told me I had just earned a raise. The foreman & I took an old barrel & turned it in to a forge with an old vacuum cleaner. Burned mesquite charcoal that really threw sparks. But it worked.
There was a big 14 inch lathe there, one AM I used it to cut off a pipe. file slipped & pealed the skin back off the top of my thumb. No big deal went on with the work with a rag wrapped around my hand. later when others go there they took me to get it sowed up. Then i went back to work. About a week later they took out the stitches I actually felt good, scratched the itch. All at once I felt faint, head spinning in turned white. Nurse laid me down. when it got better AI went home & to bed for the rest of the day.
Put 2 ear corns on the grill this AM wrapped it n foil & put in some water. Left it on for 15/ 20 minutes & got really tender & sweet. With some salt it was as sweet as water melon. Ate 1, wrapped up the other for later,
Gave Bony the cob she chewed on it for a while, then used it like a pillow.
A couple of questions - If you have any kind of an answer, please do,
What purpose dose the silk on corn serve??
How are seedless water melons planted??
As a kid was told if I ate the seeds they would grow out my ears.:laughing:
More later
Jim
   / Bad Day at Block Rock - errrr - Make it Bad Year. #752
Jim,
Corn silk brings the pollen to the cob so the kernels can form.
I don't know how seedless watermelons work!
   / Bad Day at Block Rock - errrr - Make it Bad Year. #753
They juggle the 'ploids.
Where Do Seedless Watermelons Come From?
Seed Production.
The obvious question asked about growing seedless watermelons is: "How does one obtain seed of a seedless watermelon?" Obviously, you cannot save seed from a seedless watermelon. So, where do the seeds come from? Simply stated, the number of chromosomes (the threadlike bodies within cells that contain the inheritance units called genes) in a normal watermelon plant is doubled by the use of the chemical colchicine. Doubling a normal (diploid) watermelon results in a tetraploid plant (one having four sets of chromosomes). When the tetraploid plant is bred back, or pollinated, by a diploid or normal plant, the resulting seed produces a triploid plant that is basically a "mule" of the plant kingdom, and it produces seedless watermelons. Seed of seedless varieties are available from most major seed companies.
Each planting of seedless watermelons actually produces 3 different types of watermelons -- the regular seeded watermelons (from pollinator plants), the true seedless melons, and a light-green tetraploid melon that produces a very limited number of seeds, from which next year's planting can be made.
   / Bad Day at Block Rock - errrr - Make it Bad Year. #754
Seedless water melons.....
When I was in my... lol, I guess I was 20... I made the move from the country around the thriving Metropolitan area of Lubbock, Texas. May I never tend another cotton plant cycle, chicken, goat or herd of hamburger.
I was working construction during the day and bartending at night. I was a very tall youngster and passed visual age check, things were a bit less "strict" back then. Anyways, I met a guy who said his brother/SIL had a large place and rented out a few small houses there "for what they always had" A two bedroom house, with water and free lights, but only one window unit, and limited to that one window unit could be had a 5 minute drive further into the country from the country bar I worked at, for 100$ a month... In the late 80s.
To the point, one of the perks was that they cultivated and seeded 10 acres of food plots. They plowed, and seeded, they said if God wanted them to eat it would grow. They always had an abundance, but as a renter you could go pick as much as you could eat of anything in one sitting.
Their water melon patch was interesting, several varieties but all of them had a large-ish rock on the vine the first place it touched the ground from the main plant. Except for one vine on a few plants. I asked who was responsible for the vandalism and the old gal laughed at me. She called them Cedar Chopper Seedless. Each choked vine made small water melons that the seeds were either tiny, or tiny and white. But the melons did not get very big. The vines that were not choked made some gargantuan watermelons that just split wide open with seed, very little meat. They would dry those for the next year.
They were both in their 90s when I rented from them. The lived the two of them on that land since they were married as young teens. Both were over 100 before they decided to move on, living on their own. He passed during a nap after planting during the spring one year. She passed in her sleep very shortly after his funeral.
She lined and kept lined her entire house with cucumber peels during scorpion season. There was not a leaf or rock on that property that did not have a scorpion under it, they claimed to have never had them in the house since she started that at the turn of the century.
   / Bad Day at Block Rock - errrr - Make it Bad Year. #755
More later
Jim
The silk is a sexual question... I will refrain.
Seedless melons are planted via seed. Not sure if the male or female is on the pill though to stop the cycle.
Don't laugh... the hair coming out of your ears is indeed the result of watermelon seeds. Look at the stems of the watermelon plant and tell me the hair on them is not the same as the hair that first started coming out of your ears. Difference is you started trimming your ear hair. If you didn't, maybe you would go to fruit at some point? :laughing:
OH NO How could this happen???
Someone lit the burn barrel this AM. Not only that when my back was turned they added even more paper.
If I find out who did that they will be in Big Trouble. :laughing:
Thanks fore the info on water melons & corn silk.
Had a couple of tomalies this AM. Actually tasted good for a change. A little sweet. Most every thing tastes sweet. Sweet things that I use to like are so sweet I can hardly stand them. Strange I think???
Not much to say this AM. Got to call the bank if a few. Need to know if that refund has arrived & to try once more on the ability to log on from my computer.
Tv has
   / Bad Day at Block Rock - errrr - Make it Bad Year. #757
Things tasting sweet when they shouldn't can be a medical warning sign for several problems. You should have it checked out.
Bruce
   / Bad Day at Block Rock - errrr - Make it Bad Year. #758
My annual physical is free (no copay) but I can't discuss prescriptions or what ails me unless they turn it into an office visit and I pay the $25 copay. I'm not sure what the annual physical is for, except to record my vitals. I could just as easy phone them in. I have to see doc for office visit annually now to review my prescriptions and get refills. The doc even got caught in new rules and had to do office visit before his own meds could be refilled... and we wonder why our medical costs are skyrocketing.
   / Bad Day at Block Rock - errrr - Make it Bad Year. #759
Bruce
Yeah a simple blood test is probably in order if you haven't since. I have a bro in law that recently was confirmed with diabetes that 'complained' of every thing tasting sweet. I never would have suspected as he is not overweight, eats pretty healthy. I'm surely not trying to diagnose you but I agree with Bruce on the checkup.
Hope to go to the VA fairly soon, need to reschedule my appointment. Takes about 5 weeks to get 1.
Spent most of the day on the PH.
Bank 25+ minutes.
Direct TV1 hour & 26+ minutes.
Bank thing is working
TV was working correctly for a while. With in 20 minutes it started loosing channels again. Got 1 back just trying to find out what was wrong.
had all the PH I can stand for a day or so.
Forgot to change forums that is why my post & left it incomplete. Must have made 2 dozen trips back & forth form 1 TV to the other.
more later - frustrating day.
Jim
2012 KENWORTH T800 SLEEPER (A50854)
2012 KENWORTH T800...
Yale 50LX Cushion Tire Forklift (A49461)
Yale 50LX Cushion...
Adams 5 ton Fertilizer Buggy / Wagon (A51039)
Adams 5 ton...
Adams FL24 Fertilizer Conveyor - 24IN Belt, Predator Engine, 2IN Hitch, Refurbished by Manufacturer (A51039)
Adams FL24...
2002 International 9200i Truck (A51039)
2002 International...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
