I've just been reading about the pros and cons of tractor size, and why larger is usually better. I've been thinking that I need smaller to better get through my tight tree rows, but the smaller tractors seem to lack some of the features of my Kubota B2710.
On the B2710, I have a 5' Land Pride cutter. Works great and will handle whatever I can get under it; however, I need to make some tight turns in my mowing. Problem is that I need to reverse to make these turns, and the single tail wheel has a hard time turning around. The wheel also drags across and tears up the ground. I did read a comment somewhere that 'bad things happen' when backing up with a rotary cutter. What I'm wondering is: Is there another heavy duty mower that can back up without these problems? Or can a modification be done to the tail wheel which will enable smooth backups? Thanks for any advice!
