Backhoe Backhoe removal
   / Backhoe removal
Hawkflyer,
Thank you for the detailed instructions. Fingers crossed I'll give it a try..-Terry
   / Backhoe removal #12
Pete,
Yep, I juggle it around that way too. Space is my biggest issue. I try to get as much into the 24x24 storage barn as I can so when I drop the hoe it's not in what you would call "perfect hook up position". Too much s*** in the building. One of these days I get it organized. Generally all I have to do is barely release the stabilizer pressure when it's on the floor jack and just stick my foot under the front and kick it into position. Not a big deal but lining that sucker up the first time was a bear. Actually, since my boat is in the marina and the hoe is taking up space in its winter parking spot, hookups are alot easier since I have a straight shot into it. Need a bigger building !!
   / Backhoe removal #13
It's a Bush Hog. In my previous post, I said it's more about that straight in lineup issue. If you don't have the room to come in straight, the front sf can be off either left or right a little, and once it slide onto the rear mounts it is a chore to nudge the front into position. The other reason I use the floor jack is that I can push it and angle it somewhat out of the way when it's off. A poor mans dolly if you will. Sitting there with the subframe it is a space hog.
   / Backhoe removal #14
The jack idea is good, wish I had thought of it for mounting the TPH version of my hoe. I agree that the subframe takes a lot of parking space. I am designing a "dolly" to set the hoe off on to allow me to shove it out of the way when it is parked.
JOHN DEERE 330G SKID LOADER (A58214)
JOHN DEERE 330G...
2017 INTERNATIONAL DURASTAR 4400 (A58214)
2017 INTERNATIONAL...
2021 Husqvarna YTH18542 42in Riding Mower (A56859)
2021 Husqvarna...
LAWN AERATOR (A52708)
2016 FORD F-550 UTILITY / MECHANICS TRUCK (A58018)
2016 FORD F-550...
(INOP) WESTFIELD WA8056 - 8" X 56' AUGER (A52708)
(INOP) WESTFIELD...
