back hoe will not swing in one direction, kubota L45 less then 400 hours
   / back hoe will not swing in one direction, kubota L45 less then 400 hours #1
workinallthetime
Veteran Member
Tulsa, ok
L45 TLB, ZD326P
i have noticed over the past few weekends the BH would move on its own to the right side while driving around doing loader work. A few days ago i noticed the BH would not swing from right to left w/o high engine rpm's, once i was able to move it i did not have any more trouble that day. Today it will not swing at all from right to left, swings fine from left to right.
i got off the tractor and was able to pull the BH from center to the left position while holding the lever in the direction i wanted it to swing and pulling with the other arm.
my question how would you diag if this is a cylinder problem of a valve problem? any help would be great.
   / back hoe will not swing in one direction, kubota L45 less then 400 hours #2
99% sure it is not going to be a cylinder issue. I would look into the valves and controls more. If you are looking to trouble shoot it yourself you are going to need a hydraulic pressure gauge.
   / back hoe will not swing in one direction, kubota L45 less then 400 hours #3
Swap the hoses on the swing cylinder(s).....if the problem reverses then research valve troubles, if still have problem in same direction then cylinder piston seal is bypassing or nut came off inside cylinder
BUSH HOG 32601 - 6' ROTARY MOWER (A51243)
BUSH HOG 32601 -...
2016 Kenworth T880 T/A Vactor 2112P-16 Combination Sewer Jetter Vacuum Truck (A50323)
2016 Kenworth T880...
2013 INTERNATIONAL 4300 26FT BOX TRUCK (A51219)
2013 INTERNATIONAL...
2017 Caterpillar 326FL Hydraulic Excavator (A50322)
2017 Caterpillar...
2022 Continental 16' Enclosed Trailer with ramps (A49461)
2022 Continental...
2013 FOREST RIVER WILDWOOD BUMPER PULL CAMPER (A50854)
2013 FOREST RIVER...
