Hi all....new member here.
I have a B9200 HST that won't stay running. I think it's fuel related but after after testing and trying many things I still have the same problem. Any thoughts on this would be greatly appreciated.
Symptoms are - Starts, runs and operates (moves dirt w the FEL and travels well at all throttle ranges) normally for 10 - 15 minutes. Minimal smoke at start up and no smoke while operating. Then it starts to lose power, the rpms fluctuate and then stalls. At this point it becomes hard to start and will not stay running at all. If I let it sit a couple of hrs it will start and run for another 10 minutes or so and then dies. I've repeated this process now a half dozen times with the same results.
What I did to correct this. In order
-Replaced the fuel filter. Which was clean.
-Checked the condition of the fuel and tank.No water and minimal rust inside the tank.
-Checked the fuel flow from tank to filter, filter to lift pump, lift pump to injector pump and cracked the fuel pipes to the injectors. There seemed to be plenty of fuel getting to all of these points.
-Changed the oil. There were no signs of fuel, coolant or metal in it.
-Took the injectors to a rebuilder (D&W diesel). They tested them and said they were in surprisingly good condition for their age. They did not think it was an injector pump issue and suggested I look at the lift pump.
-Replaced the lift pump.
I still have the same problem and I have no idea where to look next. Not sure, but I think I've covered the fuel related areas. One mechanic suggested that it might be a valve issue which would mean taking it to the dealer which I want to avoid if possible. Again.......would appreciate any ideas on this.
