B9200 runs but won't move???
   / B9200 runs but won't move??? #11
It sit for 3 years and now it is running fine but it will not move///it goes into the different gears(3 fwd-1rev) while running without depressing the clutch, but doesn't move what-so-ever...kubota says clutch is stuck and i need t split the tractor....and suggestions from the do-it-yourselfers??? thanks
Another question; will the PTO engage? I think that the PTO wouldn't run if the clutch wasn't engaged. If the PTO works, wouldn't that point to the rear gears not engaging? Conversly, if the PTO won't work that would deffinitly point to the clutch not engaging - I think...
I'm back...sorry it's been so long since Ihave been in the room...but when I got the B9200 home to Indiana I WD40"ed everything and really worked on that Hi-Lo range lever...it was very hard to move at first but then freed up ....Ummm i thought could it be that easy where the lever was stuck in neutral....well COOL I started it up and BINGO the clutch engaged and it backed off the trailer on it's own power.....GREAT....but then I thought dummy me :D I could have done that in texas and saved a lotta work winching the thing onto the trailer..haha....anyway The B9200 it doing AWESOME..and lots of moving gravel..I now need to get new back tires....anyone have a good sorce for the rear tires 12.4x16 ag...or what would be other tire options?? thanks again to all who gave me info ..Dave
   / B9200 runs but won't move??? #14
Check to make sure the main shaft is spinning at the transmission side. This is the shaft that feeds power to the transmission you might have a failed ball coupling. This failed on my 1986 B6200 after 900 hrs. I split the tractor from the rear end. You can split the tractor pretty easily but you need to take your time and do not force anything. Get a shop manual.
Good Luck!
2025 K2223 UNUSED Double Garage Metal Shed (A50860)
2025 K2223 UNUSED...
2019 CATERPILLAR 259D SKID STEER (A51242)
2019 CATERPILLAR...
2021 Kubota RTV X900 4x4 Utility Cart (A50322)
2021 Kubota RTV...
Bottle Storage Rack (A50860)
Bottle Storage...
2005 Sterling Acterra Tender Truck (A51039)
2005 Sterling...
2016 John Deere TS Gator Utility Cart (A48082)
2016 John Deere TS...
