B8200 snow blower
   / B8200 snow blower #1
nyone
Veteran Member
Ford 851
My plow truck is getting a bit long the the tooth so I'm going to sell it in the spring. Does anyone with a b8200 have a snow blower on theres? Is 16hp at the PTO even enough for a 5ft wide blower? Would a front blade be a better choice? It does have a loader on it.
   / B8200 snow blower #2
You'll want a 48-50 inch on that machine.
   / B8200 snow blower #3
I had an older JD750 with 19hp at the PTO with Manual transmission and used a 5' snowblower with it for many years. It worked fine even with 20" snowfalls. Was it a challenge with a manual trans, yes but I could make it work. If your tractor has HST it will be easy to match ground speed with snow load. Once the first pass is made, simply take a smaller bite if HP limited. Running at rated PTO speed helps a lot.
Also prefer to have the blower exceed the tire width by a few inches, so the rear tires clear the snow path on bends.
   / B8200 snow blower
Thanks for the info. The tractors rear tires are about 50in wide. Could I just not drop the blower all the way down and use less hp
   / B8200 snow blower #5
I've done the same also. (Keep blower lifted)
I'd rather have a wider snowblower and deal with a few work arounds than a narrow one that doesn't adequately cover the tracks.
   / B8200 snow blower #6
I have a 5 foot rear blower on my B8200 and it works just fine. Hydrostatic trans makes it easy to slow down or speed up for the snow conditions.
2010 Ford Flex SUV (A48082)
2010 Ford Flex SUV...
2020 Chevrolet Malibu LT Sedan (A50860)
2020 Chevrolet...
2006 Club Car Precedent Electric Golf Cart (A50860)
2006 Club Car...
Huffy NEL LUSSO Bicycle (A50860)
Huffy NEL LUSSO...
2019 Chevrolet Cruze Hatchback (A48082)
2019 Chevrolet...
2007 Ford Taurus SEL Sedan (A48082)
2007 Ford Taurus...
