B7800 Water pump replacement questions
   / B7800 Water pump replacement questions #1
BlueArc
Kubota B7800
Hello everybody,
I'm new to the forum and this is my first post. I have owned my B7800 for about a year now and the water pump has started to leak. I plan to replace the pump myself and was curious if anyone on the board has done this job? I searched and couldn't find a DIY or writeup on the job, any advise or hints would be great! Thanks in advance!
   / B7800 Water pump replacement questions #2
It's not hard but if you're not the original owner and have no idea of the machines' age.
You could run into lots of issues.
I suggest that you:
1) Recore and pressure test the radiator.
2) Replace both coolant hoses.
3) Replace the thermostat.
4) Carefully, very carefully, remove the studs of the water pump.
They'll more than likely snap on you
Be ready to drill and heli-coil the holes.
It's a messy job but not all that difficult.
If you've done automtoive, you'll be fine.
Awesome advice, thank you very much! I was planning to replace the thermostat, but bummed to hear about the WP studs, I hope I can avoid that!
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
miller light cooler (A50860)
miller light...
2008 Ford Crown Victoria Sedan (A48082)
2008 Ford Crown...
2011 KENWORTH T800 SLEEPER (A50854)
2011 KENWORTH T800...
2006 Ford F-150 Pickup Truck (A50860)
2006 Ford F-150...
1991 Deere 750B Long Track Crawler Dozer (A50860)
1991 Deere 750B...
