B7610 Hyd top link.
   / B7610 Hyd top link. #1
Ronster
CT
John Deere 2520, John Deere X739, Kubota U27-4, Kubota RTV 500
I searched the archives and couldn't find anyone using a hydraulic top link cylinder from Northern Tool. A 2500 psi 2" bore, 12" stroke, 22" Closed Pin distance for $62.00. Would something like this work for a top link?
   / B7610 Hyd top link. #2
Depending on the 3pt geometry of your particular tractor it probably would work. The configuration of the connecting ends would have to match your 3pt.
However, it would most likely leak down very quickly which would make you extremely disappointed in your choice of cylinders. Pay the extra money and get a cylinder designed for a top link application that has a double piloted check valve which will prevent leak down. CCM sells them (assuming their shipment has arrived). You can find many users here on TBN who have purchased from CCM and are extremely happy with their decision.
   / B7610 Hyd top link. #3
My top link cylinder is a 2" bore X 8" stroke. Closed length is 18". Original cylinder was 20" . From a suggestion by Bird I cut 2" off tractor end.
12" stroke may be to long. You may want cylinder to have a closed length as close to 18" as possible on the B7610.
   / B7610 Hyd top link. #4
Sorry to ask this, but I am new to the tractor thing and just bought a 7610 and was wondering why you want to add the Hydro Cyl. Is there an adv. (if so I may want to do the same thing). Just wondering what it does and the benifits of adding one? Sorry for the dumb question but is sounds interesting. Thanks
   / B7610 Hyd top link. #5
</font><font color="blue" class="small">( Sorry to ask this, but I am new to the tractor thing and just bought a 7610 and was wondering why you want to add the Hydro Cyl. Is there an adv. (if so I may want to do the same thing). Just wondering what it does and the benifits of adding one? Sorry for the dumb question but is sounds interesting. )</font>
Assuming you have rear aux hydraulics on your tractor, the HTL will allow you to have infinite settings on the "angle of attack" of your implement. Basically it makes adjusting the top link length really easy.
The pros and cons or having a HTL have been discussed many, many times here on TBN. Do a search for "hydrauilc top link" and have fun reading.
MadRef.., thanks for the CCM info. That's probably what I'll go for. /forums/images/graemlins/cool.gif
   / B7610 Hyd top link. #7
</font><font color="blue" class="small">( Sorry to ask this, but I am new to the tractor thing and just bought a 7610 and was wondering why you want to add the Hydro Cyl. Is there an adv. (if so I may want to do the same thing). Just wondering what it does and the benifits of adding one? Sorry for the dumb question but is sounds interesting. Thanks )</font>
Having TnT makes BB work a thing of beauty.
The hyd top link changes the angle of attack of the BB for more or less cutting with a flick of the spool valve lever.
A hyd tilt link angles the BB for crowning roads or other dirt work applications.
Well worth the investment /forums/images/graemlins/cool.gif
   / B7610 Hyd top link. #8
Ronster -
I bought a 3" x 8" cylinder - I wanted a bit of "overkill": keep in mind that for "holding" the load you use the "shaft side" of the piston (smaller working area) - but side the 3PH capacity of the B7610 isn't that enormous - so a 2" cylinder may do the trick. Having said all that - I experience no "bleed down" on my HTL cylinder - only a slow drop in the entire 3PH @ 3" every 15 minutes.
I agree with the other folks - a 12" stroke is too much for a HTL!
I use mine on a 3PH / forks bracket I fabricated - here's a link to my website 3PH - Hydraulic Top Link - that also shows a small "adapter" I had to make in order to connect the cylinder to where the top link ties in: the tie rod cylinder simply wouldn't fit as is.
Hope that helps!
Cheers,
Dan
   / B7610 Hyd top link. #9
Nice website and photos - great info and the pictures help a great deal! Now i just need to learn how to run the rear hyrdo's!
2007 INTERNATIONAL MA025 DAY CAB (A51219)
2007 INTERNATIONAL...
OIL WORKS INC. AIR TONGS (A50854)
OIL WORKS INC. AIR...
2013 Ford F-150 (A50397)
2013 Ford F-150...
4 Metal File Organizers (A48083)
4 Metal File...
UNUSED 4000PCS 12 in. Zip Ties (A50860)
UNUSED 4000PCS 12...
2007 NLB Trailer w/Mounted Shell Side System (A50860)
2007 NLB Trailer...
