enonhall
I have read the previous posts on overheating, but I am not sure my symptoms match those exactly.
I have a 1-1/2 year old Kubota B7500 HSD. In the past month it has started overheating almost immediately when mowing.
I can run it all day without the PTO engaged...no problem.
I can run it all day with the PTO engaged and the mower deck off the ground...no problem (not that I do this).
The minute I start cutting grass (even short, thick grass) the engine bogs down, black smoke emits from the engine and the temp gauge shoots almost immediately to the red.
The coolant will boil and overflow. Once left to sit, the engine cools pretty quickly. But when I restart...it all starts all over again.
I replaced the mower deck blades (they were in bad shape) and the belt (which had actually came off) two weekends ago. Didn't help. I can only assume that I got the new belt on tight enough. I asked for a tension gauge (which the manual says to use) when I bought the belt and the guy behind the counter said "nobody uses those...just make sure it's tight, but not 'banjo string tight.'" I think it falls somewhere in that range of tightness.
I keep the radiator screen clean, but I have not yet blown out the radiator itself with compressed air. Will try that this weekend. I had also planned to pick up a thermostat Sat am too, just in case that could be the problem.
Any help that anybody can provide me would be greatly appreciated! My grass is getting knee deep while I try to solve this one weekend at a time.
Thanks!
Bill
Thanks!
Bill
