B7400/B7500 history
   / B7400/B7500 history #21
Whew, sounds tough, Roger. I'll have a go at answering a few of your questions. Maybe some others can expand (or correct me if I make a mistake):
<font color=blue>What is the drive mechanism for the MMM on the 7500?</font color=blue>
It's driven by a mid-PTO under the tractor.
<font color=blue>How is the MMM raised and lowered?</font color=blue>
Part of the linkage goes back to the 3-point lower lift arms, so it's raised and lowered hydraulically via the 3-point hitch.
<font color=blue>Does the FEL and the transmission use the same fluid from a common pump.</font color=blue>
Yes.
<font color=blue>name and type of the hydraulic fluid/s use by the Kabota</font color=blue>
Naturally, the manual recommends Kubota UDT or Super UDT, but it's a universal tractor hydraulic oil (in 1995, the manual for my B7100 even listed many other brands by name; Mobil, Shell, - and I don't remember all of them, but there were 7 or 8).
<font color=blue>With the hydrostatic transmission, can the Bota be pushed or towed if the engine is not running?</font color=blue>
Yes, just put the range selector in Neutral and it rolls quite easily. I'll have to admit that I don't know about towing one long distances or at high speeds.
<font color=blue>Is the front axle drive hydrostatic or mechanical?</font color=blue>
Mechanical.
Good luck.
Bird
   / B7400/B7500 history #22
Roger,
The only clarification I'd add to Bird's response is that the MMM is shaft-driven (may not have been obvious). (Bird, thanks for responding - I wouldn't have known all the answers! /w3tcompact/icons/smile.gif)
With regard to rolling the machine - I can push my BX2200 (same weight as the B7500, but smaller) by hand when it's in neutral (just like Bird said) - but am not sure I'd want to tow it that way - having said that I'm not sure you'd have to!
I wouldn't discount the Kubota HST based on your general bad experience with HSTs. Just about everyone reading these posts has one - and I haven't read a single complaint about the kind of fluid leakage you mention. Perhaps the Kubota HST is more heavily engineered - goodness knows there are tales of them being abused on this board without any serious damage. They are also, by all accounts, a 'must have' for FEL work and also reduce mowing time due to maneuverability.
I also have not heard any complaints about the electrical system on any of the Kubotas. There are quite a few on the board who have rigged extra lights and so on - seemingly without any problems.
It certainly sounds like the B7500 (or larger) would be a tremendous step forward from where you are today. These machines are certainly engineered to last.
It's a good testimony to a machine when pretty much all the questions on a discussion board are about 'how can I do more with it' rather than 'how do I fix it'!!
Feel free to ask more questions as they arise ...
Patrick
2023 Kubota M4-061 Deluxe MFWD Utility Tractor with LA1154 Front Loader (A55315)
2023 Kubota M4-061...
14ft x 20ft Single Garage All Metal Building (New/Unused) (A59225)
14ft x 20ft Single...
2014 Sakai SV540T Pad Roller, Chassis# 3SV53-10137, PMC Power Motive, Cummins Turbo Diesel Engine, (A59076)
2014 Sakai SV540T...
2006 Columbia Medical Transport Electric Utility Cart (A56857)
2006 Columbia...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
2016 Husqarvana YTA22V46 46in Riding Mower (A56859)
2016 Husqarvana...
