If you have your owners manual it should show you how to bleed the air out of the lines , it will also tell you not to run it out of fuel for the very reason you are having now . Good luck as I have not had to do this , maybe someone will chine in with more info . .My manual just says to " fill the tank and start , run for 30 sec. and shut off ) . Not much help if it won't start .
